CD backup verify errors
Hustler
Up in the hills of Norfolk
I've just backed up some of my data to CDs using Nero and Windows XP and I've got a verify error on 3 sectors.
I've repeated the same backup 3 times now and always get the verify error on 3 sectors although the sector numbers do change each time.
I run this backup every month and last month there were no sector errors.
Backup size is 364 mb.
I've checked a few of the files that I've backed up and they were fine.
I've also backed up some different files and they worked correctly.
I assume the sectors are duff on the hard disk and nothing to do with my CD writer ?
So how can I find what is on these duff sectors ?
And how big is a sector ?
Thanks very much.
What version of Nero are you using?
If it's a later version (7 for example) you may well have a code that may tell us more.......here they are (from the Nero faq)
That may at least give a clue, but if the files work, it does sound like a data transfer error rather than a proper segment fault error on your HD.
A sector is usually 512 bytes by the way ;)
[SectorVerify]
10=Sectors from %d to %d on disc are different to source
11=Sector %d on disc has different content to source
20=Read errors from sector %d to %d
21=Read error at sector %d
30=Audio data readable but not comparable
100=Audio-verify runs with read/write-offset of %d samples
[PLUGAUDIOITEM]
0=No Error
-1=File cannot be read
-2=Read error in audio file
-3=Write error in audio file
-4=File cannot be closed
-5=Out of memory
-6=Internal error
-7=Internal illegal parameter
[CDADOC]
0=No error
-2=DRM checking failed. Not enough burn licenses available.
[VERIFYERR]
0=No error
1=Files are different
2=CD File is missing
3=Hard drive file is missing
4=Disc file is inaccessible
5=Hard drive file is inaccessible
6=Read error on CD file
7=Read error on hard drive file
8=Directory missing on CD
9=Directory missing on hard drive
10=Cannot mount the written CD
11=Drive letter of the recorder is unknown!
12=Unknown verify error
13=Status summary
14=Out of memory
15=I/O error while reading the file system structure
16=Error caused by corrupt filesystem structure
17=Error caused by supplying wrong parameters to the fs
18=Too many locks of the filesystem buffers
19=Cannot find the corresponding file system on the destination disc
20=Read error on hard drive sector
21=Backup file content differs from the hard drive data
22=Backup file contains incorrect hard drive information
[ANTIVIRSCAN]
0=No Error
1=File is probably infected by a virus
2=File could not be cured
3=File was cured successfully
4=An unknown error occurred during the virus scan
5=Out of memory error during the virus scan
6=A read error occurred during the virus scan
7=File might be infected by an unknown virus
[WAVEAUDIOITEM]
-1=Out of memory
-2=Cannot open wave file!
-3=Unexpected file format!
-4=Read error in wave file!
-5=Only PCM wave files are supported!
-6=Unsupported wave sample format!
-7=Internal error: Init is missing!
-8=Internal error!
[AVIVCDFILEITEM]
-100=Video MPEG encoder not available
-101=Invalid Video MPEG encoder DLL
-102=This version of the Video MPEG encoder DLL is not compatible
-103=Cannot create a temporary file name
-104=MPEG2 plug-in not installed
-105=Unknown error in the Video MPEG encoder
1=Not enough memory
2=Not enough encoding parameters given to the encoder
3=Unable to open the file
4=Encoding interrupted by the user
5=Cannot start video encoder
6=The parameters were not accepted by the encoder
7=Invalid video format
8=Error creating video format
9=Cannot open output file
10=Error during encoding
11=Decoder not ready
12=Cannot get bitmap
13=Disk full
14=Error retrieving information
15=The encoder cannot produce this output format
16=Unsupported file format
[DVDREALLOC]
-1=Unspecified internal error
-2=Buffer too small to hold all the information
-3=Failed to create a unique temporary file name
-4=Not enough memory to complete current action
-5=Violation against DVD specification detected
-6=Invalid parameter
-7=Too many video title sets
-8=A file item requires a pathname
-10=File access denied
-11=Invalid file handle
-12=Share violation
-13=Too many open files
-14=File '%s' not found
-15=Disk full
-16=Hardware I/O error
-17=Generic/unknown I/O error
-18=Seek beyond the file
-19=File size is not a multiple of a logical block size (2 KB)
-20=File is not a DVD file format
-21=Required file '%s' is not present
-22=File '%s' is not referenced and should not be present
-23=Video title set containing '%s' is not required
-24=One or more files (mostly VOB file(s)) do not belong to the corresponding IFO file
1=Cannot load library
2=Invalid library
3=Cannot read compilation
4=VIDEO_TS directory not found
5=Backup file '%s' should be identical to '%s'
[HDSCSIPFILE]
-1=Read error on SCSI device!
-2=Out of memory!
-3=Seek error on SCSI device!
-4=Illegal call (internal error)!
[HFSIMAGEITEM]
-2=Out of memory!
-3=Illegal call (internal error)!
[ISODOC]
-1=Error writing multisession info file!
-2=Error inserting multisession info file into compilation!
-3=Error recreating multisession CD stamp!
-4=Fatal error while trying to read HFS data from SCSI hard drive!
-5=Fatal error while trying to read boot image data! No disc in the drive?
-6=Error while creating ISO or Joliet file names!
[W95PARTREADFILE]
-1=Illegal logical drive specified!
-2=Cannot access vwin32.dll!
-3=Drive locking failed!
-4=Seek within logical drive failed!
-5=Open/Close mismatch!
-6=Read error!
-7=Cannot get drive information!
-8=Cannot write on a logical device!
[TRANSFER]
1=Aborted by user
2=Error opening file
3=Error closing file
4=Error reading file
5=Error reading cache file
6=File error
-1=General Error
-2=Error: function not implemented
-3=Error: no user interface
-4=Error: phase error
-5=Error: not enough memory
-6=Error writing file
-7=Error opening cache file
-8=Error writing cache file
-9=Error: no driver
-10=Wrong Version
-11=Error accessing cache file
-12=Capability cannot be changed
-13=Error reading cache file
-14=Error writing cache file
-15=Cache file too small - not all files could be cached
-16=Could not perform StartTrack
-17=Could not perform ReadBuffer
-18=Could not perform EndTrack
[CDR]
-1 =Unspecified Recorder Error
-2 =Bad DLL version
-3 =Recorder function not implemented
-4 =Recorder function not supported
-14 =Capability read only
-15 =Capability unknown
-20 =Queuing failed
-21 =Wait queue failed
-22 =Abort queue failed
-23 =Out of memory
-25 =Queue again later
-26 =SCSI/ATAPI command timeout error
-31 =Buffer too large
-100 =Parameter error
-101 =Invalid track info
-102 =Invalid fixinfo
-103 =Invalid track mode
-104 =Invalid pause length
-200 =Internal state error
-201 =Invalid write state
-300 =Unspecified host adapter error
-400 =Unspecified target error
-500 =SCSI command aborted
-599 =Undefined SCSI error
-600 =Device not available
-601 =Specified host adapter invalid
-999 =No SCSI/IDE command
-1000=SCSI/IDE error
-1001=Absorption control error
-1002=Application code conflict
-1003=ATIP time miscompare
-1004=Attempt to cross track boundary
-1005=Audio play aborted
-1006=Audio play stopped due to error
-1007=Barcode reading error
-1008=Block size conflict
-1009=Block size format conflict
-1010=Buffer data size error
-1011=Buffer error during recording
-1012=Buffer overflow
-1013=Buffer underrun
-1014=Calibration area almost full
-1015=Calibration area full
-1016=Cannot read ATIP
-1017=Cannot recover from lead-in
-1018=Cannot recover from lead-out
-1019=Cannot recover from PMA
-1020=Cannot recover from callibration area
-1021=Cannot recover from track
-1022=Command currently not valid
-1023=Command sequence error
-1024=Communication failure
-1025=Current command aborted
-1026=Current program area empty
-1027=Damaged track present
-1028=Damaged track detected
-1029=Data track length error
-1030=Diagnostic failure
-1031=Disc is write protected
-1032=Disc style mismatch
-1033=Drive not ready
-1034=Dummy blocks added
-1035=EEPROM failure
-1036=End of disc reached
-1037=End of user area of this track
-1038=Exit packet write area
-1039=Focus or tracking error
-1040=Illegal block size for command
-1041=Illegal cue sheet
-1042=Illegal cue sheet length
-1043=Illegal cue sheet parameter
-1044=Illegal field in command
-1045=Illegal form for reserved track
-1046=Illegal disc
-1047=Illegal mode for this track
-1048=Illegal packet mode
-1049=Illegal reserve length
-1050=Illegal reserve packet length
-1051=Illegal track
-1052=Illegal track descriptor table
-1053=Illegal track descriptor unit
-1054=Illegal track mode
-1055=Illegal track number
-1056=Illegal track status
-1057=Illegal transfer length
-1058=Inappropriate command
-1059=Initiator detected error message received
-1060=Internal controller error
-1061=Internal target failure
-1062=Invalid audio address
-1063=Invalid bits in identify message
-1064=Invalid block address
-1065=Invalid command
-1066=Invalid field in command
-1067=Invalid field in parameter
-1068=Invalid LUN
-1069=Invalid message error
-1070=Invalid start address
-1071=Laser current over
-1072=Laser adjustment error
-1073=Link area encountered
-1074=Link blocks encountered
-1075=Logical unit is reserved
-1076=Disc changed
-1077=Disc format corrupted
-1078=Disc load mechanism failed
-1079=Disc load or eject failure
-1080=Disc not present
-1081=Disc removal prevented
-1082=Message error
-1083=Mode parameters changed
-1084=Monitor ATIP error
-1085=Nonexistent block encountered
-1086=Not enough space
-1087=Not ready to ready transition
-1088=No additional sense information
-1089=No barcode available
-1090=No EFM at search address
-1091=No packet
-1092=No pregap
-1093=No seek complete
-1094=No TOC
-1095=No track for finalize
-1096=Disc should be removed
-1097=Overlapped command attempted
-1098=Packet size mismatch
-1099=Parameter list length error
-1100=Parameter list too long
-1101=Parity error
-1102=PCA area full
-1103=PMA area full
-1104=Positioning error
-1106=Power calibration error
-1107=Program area not empty
-1108=Recovered data with ECC
-1110=Recovered data with retries
-1111=Recovery needed
-1112=Request for fixation failed
-1113=Reserved track present
-1114=Reset occurred
-1115=Select or reselect failure
-1116=Selftest failure
-1117=Stopped on nondata block
-1118=Track-at-once not in PMA
-1119=Track following error
-1120=Tray out
-1121=Unable to read TOC, PMA, or subcode
-1122=Unable to recover TOC
-1123=Unable to reserve track because track mode has been changed
-1124=Unknown disc format
-1125=Unrecordable disc
-1126=Unrecoverable damaged track has made writable area too small
-1127=Unrecoverable track descriptor encountered
-1128=Unrecoverable read error
-1129=Unwritten area encountered
-1130=Verify failed
-1131=Write append error
-1132=Write busy
-1133=Write complete
-1134=Write data error with CU
-1135=Write error
-1136=Write illegal block length
-1137=Write operation in progress
-1138=Writing lead-in or lead-out in progress
-1139=Audio play in progress
-1140=Audio play completed
-1141=Invalid parameter list length
-1142=Synchronous data transfer error
-1143=Blank CD
-1144=No PMA
-1145=OPC initialization error
-1146=OPC execution error
-1147=OPC ALPC error
-1148=OPC timeout
-1149=Read address is ATIP
-1150=Write address is EFM
-1151=Write emergency occurred
-1152=Disc speed error
-1153=Disc not identified
-1154=Disc not supported
-1155=Write emergency
-1156=Servo error
-1157=PLL error
-1158=Address error
-1159=Header monitor error
-1160=Header search error
-1161=EDC error
-1162=Link/RI/RO error
-1163=CDBD overrun error
-1164=Write audio on reserved track
-1165=Hardware error
-1166=Invisible track present
-1167=Incomplete track present (perhaps a CD-RFS-CD?)
-1168=Unknown track present
-1169=Logical unit not ready, operation in progress
-1170=Insufficient time for operation
-1171=Read timeout
-1172=Write timeout
-1173=Read Write Control Task Error
-1174=Mechanism Control Task Error
-1175=Internal trace
-1176=Session fixation error
-1177=CLV speed invalid
-1178=Recovered error
-1179=Disc error
-1180=Illegal request
-1181=Unit attention
-1182=Data protect error
-1183=Blank check command error
-1184=Vendor-specific error
-1185=Copy command aborted
-1186=Volume overflow error
-1187=Data miscompare error
-1188=Disc is not formatted (esp. important for DVD+RW)
-1189=Cannot read disc - incompatible format
-1190=DVD problem - no key to read protected DVD
-1191=Erasing failure
-1192=Erasing failure - incomplete erase operation detected
-1193=Disc is writable but not empty
-1194=PMA update failure
-1195=Disc not present - tray closed
-1196=Disc not present - tray open
-1197=Drive is in use by another application
-1198=Drive is in use by another application
-1200=Invalid address for write
-1201=Drive is in use of InCD
-1202=Drive is in use of IMAPI
-1203=Failed to lock IMAPI
-1205=Burning Layer 1
-1206=Burning Layer 2
-1207=Book Type automatically set to: %s
-1208=DVD-ROM
-1209=Physical disc type
-1210=Current recorder setting
-1211=Book Type set to: %s
-1500=DMA-driver error, timeout occured
-1501=DMA-driver error, parity error
-1502=DMA-driver error, CRC error
-1503=Device handle invalid
-1504=Medium format corrupted
-1505=Medium format failed
-1506=Zoned formatting failed due to spare linking
[IMAGEGEN]
0 =No error
1 =Aborted by user
2 =File missing
3 =File has the wrong format
-1 =Unspecified Imagegenerator Error
-2 =Could not perform StartDisk
-3 =Could not perform StartSession
-4 =Could not perform StartTrack
-5 =Could not perform Write
-6 =Could not perform EndTrack
-7 =Could not perform EndSession
-8 =Could not perform EndDisk
-9 =Error during ISO relocation
-10 =The image chunks:
-11 =Error during generation of Disc-at-once information
-12 =Cannot write track at correct position with this recorder
[ISO9660GEN]
-3 =Joliet names of these files (listed here in ISO-L3) are the same:
-4 =The ISO 9660 Generator ran out of memory
-5 =The following fixed file has an illegal position
-6 =Preparation of ISO 9660 structures failed
-7 =Too many files in one group of interleaved files
-8 =IO error using the boot image
-9 =Cannot allocate space on the CD-R
-10 =Boot sector not recognized
[MAKEJOLIETNAMES]
-3 =The listed files have no unique Joliet name:
[PHASE]
1 =Reading directories
2 =Creating directories
5 =Writing files
6 =Finishing
9 =Prepare audio writing
10 =Writing audio
11 =Writing Audio Track
12 =Finishing
13 =Prepare HFS
14 =Writing HFS
15 =Writing HFS completed
16 =Prepare Image
17 =Writing Image
18 =Burn Image
19 =Finishing
20 =Reading of disc started
21 =Reading disc completed
22 =Reading disc failed
23 =Reading disc aborted
24 =Caching of files started
25 =Caching of files completed
26 =Caching of files failed
27 =Caching of files aborted
28 =Speed measurement started
29 =Speed measurement completed: %s
30 =Speed measurement failed
31 =Speed measurement aborted
32 =Simulation started at %s
33 =Simulation completed successfully at %s
34 =Simulation failed at %s
35 =Simulation aborted
36 =Burn process started at %s
37 =Burn process completed successfully at %s
38 =Burn process failed at %s
39 =Burn process aborted
40 =Aborted by user
41 =Compilation will not fit onto a blank disc
42 =Writing lead-in
43 =Writing lead-out
44 =Writing lead-in and lead-out
45 =Generation of disc identification started
46 =Generation of disc identification finished
47 =Generating relocation information
48 =Analyzing disc
49 =Reading track info
50 =Reading Media Catalog Number
51 =Reading ISRC
52 =Finding end of track
54 =Copying disc
55 =Completing
56 =Unspecified Error. The burn process failed!
57 =Disc-at-once overburning option activated
59 =Writing hard drive backup track
60 =Completing
61 =Simulation started
62 =Simulation completed successfully
63 =Simulation failed
64 =Simulation aborted
65 =Burn process started
66 =Burn process completed successfully
67 =Burn process failed
68 =Burn process aborted
69 =Scanning Indexes
70 =Only the recording of the first session can be Simulated
71 =Writing several sessions at once. Result may be unreadable on some drives.
73 =Preparing items
74 =Checking discs
76 =Write speed changed due to disc type
77 =Writing tracks
78 =Data verification started
79 =Data verification aborted
80 =Data verification completed successfully
81 =Data verification failed
82 =Encoding video
83 =Virus scanning started
84 =Virus scanning completed
85 =Virus scanning completed. A virus was found and burning must be aborted!!!
86 =CD TEXT is not supported
91 =Poor performance by your DMA chipset driver (look for updates)
92 =Recording quality may be affected by not using JustSpeed option
93 =Unable to write at this speed. Please select a slower speed and try again.
98 =Start formatting disc before burning
99 =Formatting disc before burning
100 =Formatting disc was successful
101 =Formatting disc failed
102 =Fast user switching detected. This may cause buffer underrun.
105 =Preparing Audio CD-RW (erasing TOC and/or tracks)
106 =Preparing of Audio CD-RW (erasing TOC and/or tracks) completed
107 =Audio CD-RW preparations failed
108 =Audio CD-RW preparations aborted
109 =Warning: Disabling SMART-BURN function may result in writing errors and impact on the quality of disc recorded.
110 =Recorder does not support writing in Raw+96 mode on CD-RW.
111 =DVD-Video files sorted
112 =DVD-Video files reallocation started
113 =DVD-Video files reallocation completed
114 =DVD-Video files reallocation completed (no file modified)
115 =DVD-Video files reallocation failed
116 =VariRec disabled - no Audio CD
117 =DVD-Video files compliance test failed
118 =SSW (Super Speed Writing) activated
120 =Creating the image for burning
121 =Creating Image completed successfully
122 =Burning the bitmap to the disc started
123 =Burning the bitmap to the disc completed successfully
124 =Burning the bitmap to the disc failed
125 =Burning the bitmap to the disc aborted
126 =Best write speed for disc detected
127 =Generating DVD high compatibility borders
128 =Generating DVD high compatibility borders
129 =Generating DVD borders completed successfully
130 =Generating DVD borders aborted
131 =Recording quality may be affected by not using the PoweRec option
132 =DVD-Video files compliance ignored
133 =Writing short lead-out
134 =Quick Grow last Border
135 =Quick Add Border
136 =Quick Format DVD-RW
137 =Image transfer started
138 =Image transfer completed successfully
139 =Image transfer failed
140 =Image transfer aborted
141 =Label transfer started
142 =Label transfer completed successfully
143 =Label transfer failed
144 =Label transfer aborted
145 =Burn process and image transfer started
146 =Burn process and image transfer completed successfully
147 =Burn process or image transfer failed
148 =Burn process and image transfer aborted
149 =Network transfer completed successfully
150 =Network transfer failed
151 =Authentication failed
152 =Server connection failed
153 =Server license error
154 =Recording quality may be affected by not using Auto Pilot option
156 =Drive is in use by another application
159 =The simulation has been done at %s speed by PoweRec
160 =The write has been done at %s speed by PoweRec
161 =Burn process completed successfully with warnings
162 =Simulation completed successfully with warnings
166 =Simulation is not supported for this disc type
167 =Not able to write Disc-at-once on an open disc.
168 =Compilation cannot be written on the selected recorder(s)
169 =DRM checking failed. Not enough burn licenses available.
170 =Not possible to burn more than 154 sessions to a DVD disc.
171 =Writing data files started
172 =Writing data files completed successfully
173 =Writing data files failed
174 =Writing data files completed with warnings
175 =Finalizing disc started
176 =Finalizing the disc failed
177 =Disc finalized successfully
178 =Preparing the disc failed
179 =Writing file to disc failed
180 =Copy process failed during reading.
181 =Writing lead-out...
182 =Burn Proof activated
183 =SolidBurn activated
184 =SolidBurn activated
185 =Overspeed burning activated
It might be modified blocks in the filesystem that have changed since the backup, and you probably don't need to worry too much. Things like dates in directory blocks if you touch any file/dir. There's no obvious system files in the set is there, that would definitely change over time?
No system files, no just own personal data stuff.
Here's the error log below for interest/comment and thanks for your time Fanum and ianf, appreciated. -
1A23-0609-9030-2348-0264-7843
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26/10/2004 18:35:34
Nero Version: 6.6.0.14
Internal Version: 6, 6, 0, 14d
(Nero Express)
Recorder: <SONY CD-RW CRX320E> Version: NYK5 - HA 1 TA 1 - 6.6.0.14
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <SONY CD-RW CRX320E >Version: NYK5 - HA 1 TA 1 - 6.6.0.14
=== Scsi-Device-Map ===
DiskPeripheral : Maxtor 5T040H4 atapi Port 0 ID 0 DMA: Off
CdRomPeripheral : SONY CD-RW CRX320E atapi Port 1 ID 1 DMA: On
=== CDRom-Device-Map ===
SONY CD-RW CRX320E D: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 70254592 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 479MB (490852kB)
Free physical memory: 198MB (203184kB)
Memory in use : 58 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
2.1.2008
CD-ROM (ISO)
21:03:49 #1 Text 0 File Isodoc.cpp, Line 6314
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : TAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
21:03:49 #2 Text 0 File Burncd.cpp, Line 2945
SONY CD-RW CRX320E
Buffer under-run error protection activated
21:03:50 #3 Text 0 File Reader.cpp, Line 127
Reader running
21:03:50 #4 Text 0 File Writer.cpp, Line 122
Writer SONY CD-RW CRX320E running
21:03:50 #5 ISO9660GEN -11 File geniso.cpp, Line 3297
First writeable address = 0 (0x00000000)
21:03:50 #6 Text 0 File Burncd.cpp, Line 3230
Turn on Track-At-Once, using CD-R/RW media
21:04:07 #7 Text 0 File DlgWaitCD.cpp, Line 267
Last possible write address on media: 359845 ( 79:59.70)
Last address to be written: 186659 ( 41:30.59)
21:04:07 #8 Text 0 File DlgWaitCD.cpp, Line 279
Write in overburning mode: NO (enabled: CD)
21:04:07 #9 Text 0 File DlgWaitCD.cpp, Line 2433
Recorder: SONY CD-RW CRX320E;
CDR code: 00 97 27 66; OSJ entry from: Ricoh Company Limited
ATIP Data:
Special Info [hex] 1: C0 00 B0, 2: 61 1B 42 (LI 97:27.66), 3: 4F 3B 47 (LO 79:59.71)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 80 80 (invalid)
21:04:07 #10 Text 0 File DlgWaitCD.cpp, Line 445
>>> Protocol of DlgWaitCD activities: <<<
Insert the disc to write to.
(Medium in drive: Unknown. Medium required by compilation: CD-R/RW.)
21:04:07 #11 Text 0 File ThreadedTransferInterface.cpp, Line 830
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 186660 (186660) = #186660/41:28.60
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 186658 blocks [SONY CD-RW CRX320E]
21:04:08 #12 Text 0 File Burncd.cpp, Line 3824
Can only write at 40x (6,000 KB/s) instead of 52x (7,800 KB/s) to current disc.
21:04:08 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [SONY CD-RW CRX320E] for write in TAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 382586880, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
-150 | lead-in | 0 | 0x41 | 0x00
-150 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
186660 | lead-out | 1 | 0x41 | 0x00
21:04:08 #14 Text 0 File ThreadedTransferInterface.cpp, Line 1111
Removed 2 run-out blocks from end of track 1. Length: 186660 -> 186658.
21:04:08 #15 Phase 24 File dlgbrnst.cpp, Line 1832
21:04:33 #16 Text 0 File Burncd.cpp, Line 4114
Cache writing successful.
21:04:33 #17 Phase 25 File dlgbrnst.cpp, Line 1832
21:04:33 #18 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 40x (6,000 KB/s)
21:04:33 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
21:04:33 #20 Text 0 File Mmc.cpp, Line 21592
Set BUFE: Buffer under-run error protection -> ON , SMART-BURN : ON
21:07:19 #21 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
21:07:31 #22 Text 0 File Mmc.cpp, Line 16240
<SONY CD-RW CRX320E > start Close Session
21:07:46 #23 Phase 37 File dlgbrnst.cpp, Line 1832
Burn process completed successfully at 40x (6,000 KB/s)
21:07:46 #24 Phase 78 File dlgbrnst.cpp, Line 1832
21:07:49 #25 Text 0 File ThreadedTransferInterface.cpp, Line 1111
21:10:25 #26 SCSI -1128 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x0B5C0200
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 0x00 0x00 0x02 0xD9 0x1E 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x02 0xD9 0x1E 0x0A
0x00 0x00 0x00 0x00 0x11 0x05
21:10:28 #27 SCSI -1128 File Cdrdrv.cpp, Line 1436
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 0x00 0x00 0x02 0xD9 0x1F 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x02 0xD9 0x1F 0x0A
21:10:35 #28 SCSI -1128 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03C85600
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 0x00 0x00 0x02 0xD9 0x20 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x02 0xD9 0x20 0x0A
21:10:38 #29 SCSI -1128 File Cdrdrv.cpp, Line 1436
Sense Code: 0x11
Sense Qual: 0x05
CDB Data: 0x28 0x00 0x00 0x02 0xD9 0x21 0x00 0x00 0x01 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x02 0xD9 0x21 0x0A
21:10:38 #30 Text 0 File ThreadedTransfer.cpp, Line 228
21:10:38 #31 SectorVerify 20 File Cdrdrv.cpp, Line 9853
Read errors from sector 186654 to 186657
21:10:38 #32 Phase 81 File dlgbrnst.cpp, Line 1832
Existing drivers:
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 03/08/2004 22:59:44 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
A suggestion - if you have virtual drive software (something like MagicDisc or MagicIso) that is creating virtual CD drives they will cause verification errors - get rid of all the virtual CD drives before writing a CD.
Can't see much wrong there.......you get the
message.......
There's an error concerning a time out, that may be due to spin down time or other processes hanging the time up too much......
I'm far from being an expert on it, but I wouldn't be worried (TBH I never even bother with verification when i burn stuff!) and if it works, it works....
Make sure you're fully defragged (changing your swapfile to another partition is a good idea) and as long as you have a useable copy of whatever you were backing up, don't worry about it ;)
message.......
Thanks Fanum, I never used to bother with verification but started to use it a while ago. I do quite religiously run backups now though, since I had the hard disk fry after the fan stopped working that is.
I digress.
No MagicDisc or MagicIso here Bob (don't even know what they do to be honest).
Thanks for your time people, I'll stop worrying although I wasn't overly concerned but thought I'd better ask an expert just in case.
Might be worth thinking about another approach.....what are you actually backing up???
If it's Emails and files, try doing a files and settings backup which will give you a .pst file....then save than onto CD or even onto a 250 gig HD (about £70 from pretty much any pc place)
There are numerous backup places online- some free, some cost, but if you have broadband and the info isn't seriously sensitive, that might be a good palce to dump a spare copy of stuf.
Acronis is also a great thing to play with.....back up everything, do a file and settings save then re-install the whole OS inc AV, fancy drivers and flash, quicktime, firewall, desktops etc etc then save an exact image- after that, all you have to do is an incremental backup using Acronis and for double safety a PST file save and you're pretty well backed up ;)
I'm only backing up personal data.
Stuff like Acronis is getting into unknown territory for me and we moved from the UK to France last year and my little geek friend refuses to come over to our new abode to sort me out when I have a problem so trying to keep things really simple if I can.
But thanks for the suggestions.
Acronis is a great solution and pretty simple to use. hardest part is creating a partition for it to write to, and that's not rocket science :)
Run a disk check in a command prompt...
chkdsk C: /F /R
it will say something like "disc in use schedule check after reboot y/n" - when you reboot it will check the disc sectors before restarting XP
