Been a long evening last night, but I got there eventually.
I did not want to cut up original loom supplied with the unit, so has to do some adapting work. By using 6” of two core cable, crimping two banjo connectors on one end and. Bolting these together with stainless steel M6x8mm bolts & and half (lock) nuts. Then slipped corresponding colour 3:1 heat shrink over each joint. The opposing ends on the 6” cable were adorned with a pair of spade crimps, head shrink over the top of that too, to make it waterproof.
KTM are excellent at providing you easy power source. ACC1 being permanent live, and ACC2 being switched live. Getting there though involves removing the headlight, which is a bit of a PITA.
The CHIGEE loom has three cables that need connecting. The red and the black go to battery terminals. As mentioned above I did not do that. Instead adapted it to fit connectors behind the headlight. The red and black went into ACC1 and a single yellow (trigger wire) went into the positive terminal of ACC2 connector.
A quick test before putting the bike back together and it is a success.
Unit powers up and ready in circa 10-15 seconds.
Phone connects to the unit in under 10 seconds. All wirelessly, by first establishing a Bluetooth connection, then using its own WiFi connection to keep it going and assuming to prevent the phone from being drained to quickly.
In my Givi tank bag, I have their own USB power hub. Which is connected via fly lead to a connector mounted just in front of the fuel tank but behind a right fork leg (see photo bellow, bottom right corner)
I do not mount the phone anywhere on the bike, as I just don’t like to have to much clutter, in the tank bag it is safe, but also meant it goes get a charge out of the elements.
Anyway, the unit is up, just need to set up the apps properly, and link intercom another way if the current setup does not work. That ride to my Local J&S shortly.
Will report back.
