Chunky needs a new whip...
WrexhamWrider
Member
Wrexham
Hello folks.
I'm wondering if any you could help me out with some wisdom and opinion. I'm quite a new biker who is still learning learning the ropes, and wondered if the UKGSer hive mind could give me their thoughts on the following scenario, which may/may not lead to me getting a GS.
I've had a Moto Guzzi V85 for a couple of years and it's been great.
I'm about 18 stone (114 kg), 6ft (183 cm) tall with a 32" (81 cm) inseam; not the heaviest or tallest rider ever, but I do suffer with back pain, and I'm having a bit of trouble getting comfortable when touring on my V85. For unladen days out, the V85 is fantastic; I like the low end torque, the fact it can cruise at reasonably low revs, and the rumble of the v-twin is always pleasant. Once I'd fitted bar risers and a high-seat, I found I could spend a good few hours on it without pain. The trouble is that when doing multiple days in the saddle, my back takes a beating. I *think* I've nailed the issue: my weight + the weight of luggage = pushing the suspension/frame beyond its capabilities. I've set the sag at about 30% for me in my gear only, and that needs the preload at about 75%. Loading up the panniers and topbox, I can't get anywhere near that level of sag even with preload maxed out. I'm not filling them with anvils or anything either; I've got a D-lock and chain which I strap to the pillion seat in a drybag, off-bike clothes in one pannier, small toolkit/waterproofs in the smaller pannier, and the top box tends to have stuff I might need when stopping for a break (snack/drink/cap/spare sweater/gloves etc).
I've looked into upgrading the suspension on the V85, but it's going to cost me a good few quid, and I'm into the final year of my PCP agreement. If I was going to keep the V85, that's no problem, but there is always the danger that I spend all that money on the suspension and it's only marginally better, or something shiny catches my eye in the next 12 months.
As such, I decided to test ride some heftier bikes, to see how they differed, and whether they may be more suitable for my fat arse and all my touring chattels. I'm working my way through a shortlist, which I'll outline below with my thoughts. Obviously I've only tested them without luggage at this point, so happy to take advice about whether they'd suit me. I know, it sounds like what I need is a car (or a Goldwing). I've put off test-riding the GS because I think they might be the (expensive) answer. I hovered over the buy button on the Triumph, but I dunno, I just couldn't quite do it.
I don't mind used at all, but I've set myself an upper limit of £200/month and you have to go really old for HP at £200/month; I'm done with spannering if I can help it, so I'm looking at PCP which tends to be newer stuff.
These are all current models, and my use case is tarmac only:
Honda Africa Twin Adventure Sport ES Manual​
Pros: the growl, torque, feels nice and flickable, could get the ride nice and comfy, I quite like the Apple CarPlay thing, probably very reliable​
Cons: not much legroom, chain drive, a bit expensive, and I've heard the valve service can be a bit pricey; not mad keen on the looks​
Kawasaki Versys 1100 S​
Pros: goes like stink, smooth, good wind protection, nice ride even without tweaking (not the SE with electronic suspension), seems well made, probably very reliable​
Cons: not much legroom, chain drive, riding position a bit sportier than an ADV, a bit plain on the looks front.​
Moto Guzzi Stelvio Duecento Tributo​
Pros: noise, torque, noise, looks, shafty, price, endless gizmos, I like my local Guzzi dealer, I like being a Guzzi rider​
Cons: not much legroom, shocking ride, maybe a bit raw for touring, potential reliability​
Triumph Tiger 1200 GT Pro (Alpine Edition)​
Pros: easily the most comfortable bike I've ever ridden, loads of legroom, riding position spot on, feels lighter than it is, smooth, goes like stink, relaxed at speed, loads of tech, doesn't look too bad, great deals on them at the mo​
Cons: do I really want to be a Triumph rider? potential reliability, seems a bit expensive for a bike cobbled together in Thailand, and I've heard the valve service can be a bit pricey​
I'm yet to test the following, but these are my preconceptions:​
BMW R1300GS/GSA​
Pros: comfort, shafty, boxer twin is appealing for low down torque and general quirkiness, good residuals mean cheaper PCM costs​
Cons: I'm not sure I want to spend that much on my hobby for the amount I get to do it; GS seems a bit sporty, GSA seems a bit in-your-face, needs the warranty​
BMW R1250GS/GSA (used)​
Pros: comfort, shafty, boxer twin is appealing for low down torque and general quirkiness, good residuals mean cheaper PCM costs, cheaper than a 1300​
Cons: looks, GSA seems a bit in-your-face, and I've see far too many "GS Bros" cosplaying as Ewan McGregor, needs a warranty​
Honda NT1100​
Probably ideal, but too minging​
KTM 1290 Super Adventure​
Nope!​
Suzuki V-Strom 1050RE​
Pros: cheap​
Cons: cheap​
Proper non-ADV touring bike​
Never tried one. Is this the answer with my back?​
Get a twin cam 1200, late 2011 or 2012
6k will get you a very nice example
Spend any spare cash on suspension, bar risers and seat
Easier to fix. Less electronics to go wrong
Job done
That does sound appealing. That's why I posted. Thanks.
All of those bikes have an upright riding position. This might be the root cause of back trouble as you are bearing all of your upper body weight through your spine. Ride a bike with a forward lean and you take some weight through your arms.
I have owned a Triumph 1200 Explorer. It had the best suspension I have had on a bike. It was a UK made one. I could not get on with the top heavy weight. I part exed it after a trip to the Alps for a used BMW S1000XR which you should try, as well as other similar tall rounders.
Try a BMW RS. Same mechanicals as the GS, same shaft drive, forward lean, proper forks. I owned one at the same time as the XR. These are by far the best bikes BMW make for touring. I owned a R1150GS for 10 years and loved it but I have never been a fan of more recent GS, having been given them as loan bikes when having the XR & RS serviced. The XR went in 2023 as part of my down sizing to enable retirement at 60.
You list the Versys. Try the sportier SX version as it is very good apparently. Maybe the Tracer and V100 Mandello as well.
My own joint problems, right hip, meant I have since changed the RS for a V85TT Travel. That 20 degree lean was no good for me. I've done 3 trips into France/Spain on the V85 in the last year and about to go on a fourth. It suits me but I am a bit shorter and a bit lighter.
I’m genuinely surprised you can’t get the suspension right solo even with your weight and that luggage. I upgraded my v85s rear shock but only as I did 90% of the mileage two up and pegs and feet touched down far too easily and dangerously on corners. Our combined weight even without luggage was close to the max payload for the bike (which is something like 225kg iirc) and with luggage well north of it. 18st is probably 19st in bike gear but is still only about 120kg. I doubt very much you are adding 100kg+ of luggage. Lots of people ride these bikes two-up without problem.
We did a couple of multi-month euro tours on my v85 complete with camping stuff with the upgraded shock. It was fine although wheel bearings and spokes did prematurely wear/break. Buy the high seat (they come up used on eBay), add a Cool Cover seat cover and you gain 3+inches of height and loads of comfort. Add some SWmotech footpegs set on low and you open your sitting position no end.
The alternative to a whole new shock would be to get the spring and damping of your existing shock upgraded. Probably be about £200 ish, I dunno, but cheaper than a shock.
You say you are inexperienced. Bikes are noisy and uncomfortable things. Always have been, always will be. Some bikes are bit noiser than others (v85 is a noisy one) some are more comfortable than other (v85 is imho a very comfy bike). Managing “a good few hours without pain” is about as good as it gets until you are several days to a week into a trip after which the saddle becomes your happy place. Make it a routine to wriggle about every so often, curl your toes, hold your core firm for a few moments every now and then or whatever suits you. These just keep muscles active and stops them stiffening. That’s what we both do on long days. Equally though nowadays we rarely do stretches of more than 2-3hours in the saddle.
As for those other bikes, they’ll all be noisy and uncomfortable but just in different ways to the v85. I/we upgraded to a Stelvio 1200. So a bit like @Santa-2512 ’s suggestion buy a cheaper bigger bike and spend on upgrades that can be swapped out if or when you move it on. In our case we needed a tad more power for our combined weights. The v85 just wasn’t quite good enough. If you like the character of the v85 you’ll love a Stelvio. Plenty of go from a fabulous engine. Good handling which is much better than the v85 ever was and it shrugs off weight. They are very heavy and tall beasts though. Buy 2013 or later so you don’t have to worry about flat tappets.
The Honda NT1100 isn't minging - it's a very good bike. My touring mate has one - we've been to the 4 corners of Europe - and his bike has been superb. FWIW.
kits used to be £1100 , £400-550 to fit. you can buy the bits individually , for lots more .
but spending £2k on a bike worth £3k , doesn't make the bike worth £5k.
i it ain't got rollers , AVOID . ( unless it is really cheap , and i mean REALLY CHEAP )
driving around with fucked flat tappets WILL kill your big end shells , and if they damage the crank , get another engine.
Thanks for the reply, and yes, I can see how a different riding position would change the amount of fatigue in my back.
However, if I ride my V85 without luggage every day for a week without luggage (days out from home), I don't get back ache. Five days with luggage and I do; same bike, same riding position. Without luggage, I find the bike really comfortable.
Given that the V85 can take lighter two up + luggage loads comfortably, it doesn't really make sense that I should be uncomfortable, but I am. I am prone to occasional back problems, so maybe that is it rather than the V85 being generally uncomfortable. I do tend to ride slightly canted forward anyway, bum slightly back in the saddle, and I have the optional high seat; not as much as on the Versys, but more than the stock seat or with my bum further forward.
I think I just need to find something that is kinder to my back, whatever that is. I'll get there in the end.
I wonder if this is a suspension thing? With the added weight, maybe there is more transmission of road vibrations?
Have you seen a physio? When I had joint problems (hip and shoulder) I found doing some resistance based strength exercises helped. You should be able to self refer without seeing a GP. I did it in Cheltenham and here in Powys.
Yeah, I've already got the high seat.
I'm inexperienced, but I've done nearly three years so far, so I'm not *that* inexperienced. The rest of me is okay; I don't get a numb bum, arm fatigue or leg fatigue (which I did on a smaller bike); I'm pretty strong, so I don't have any other bike fitness issues, it's just my back, which I struggle with off the bike as well to be fair. Maybe the V85 is comfortable enough for somebody with a healthy back, but it doesn't work for me. I'm exploring my options. Thanks for the thoughts, though.
I hadn't considered one of those. Thanks for the tip!
Usually known as kidney belts. I have had them for years.
Stops your back muscles getting chilled/aching
The modern elastic and Velcro kidney belt used today was born in the late 1910s and 1920s. It was invented specifically for early motorcyclists to protect their lower backs and internal organs from the intense vibrations and jarring impacts of riding un-suspended bikes on rugged dirt roads.
Yeah, I do get a lot more vibration up my back with the added weight, rather than it bottoming out. I notice it especially on motorway expansion joints and on poor surfaces. Without luggage, no problem at all, it's like sitting on my sofa (just a bit windier).
Physio is a good shout, but I have seen my quacks about it previously, multiple times, and they've put it down to the usual suspects: growing old/carrying too much podge/bad posture at work. I'm sure a physio would help, but getting a comfier bike with a plusher ride is both easier and more fun.
I've got a GS test ride booked in for later this week. I won't be able to try it with luggage, but it's got to be more comfy than a V85, surely.
