Clutch Problems!?!
  • Thread starter Thread starter Avaword
Avaword
My trusted steed has developed a worrying clutch problem in the last few days which originally surfaced a couple of weeks ago. I noticed recently that the bite point had moved from its normal position from midway between releasing the lever to full extend to a couple of cm's from the bars....the next time I used the beast a few days later things had returned to normal!?!....Then travelling home from work in London to the south coast last night the same problem resurfaced to the point that I was having to blip the throttle to select a gear.I have tried to adjust the clutch from the lever...not much of an improvement..Is the cable knackered or something else???....all comments gratefully recieved....cheers.
rubber gearbox to engine bolts.
Clutch Problem Sorted!!!!
:clap :clap ....Turned out to be the slave cylinder...those good eggs at Prestige fixed it in a jiffy and nothing to pay either...don't you just love warranty!!!
