Collector box gone manky
Bill-H
Di-di-dah-dit di-di-dah
Norf Staffs
Fired up my 1989 R100GS today, it's not been run since the Autumn, now I know it was beginning to blow a bit from the collector box, but wasn't prepared for the row as it seemed to spring leaks as it fired up.
Took it apart today, and even as I loosened the clamps, I could see it was holed just where the rear box joined the Collector, so I took them both off together.
It's holed in three places, 1/4 way round as above, rather badly around where the curved clip goes over the frame, and a small hole one one side of the box.
It's been welded before by the look.
A quick Google seems to show that there's not too many around. Where should I be looking or what other options should I be looking at?
Ta.
Motorworks will 'do you' a new one (a few hundred £££'s) or a Khienan (don't think that's spelt correctly) 'y' piece - might be one or two in folks' sheds if you put an ad up.
Good luck!
Thanks, I'll give Motorworks a ring on Monday, they have a couple listed on their web site - if it's up to date.
Y piece is not my first choice as I understand even running might be compromised a little.
