Air escaping at the nipple when using a Mityvac.Sorry I don’t get you. What is normal when bleeding brakes? Air escaping at the nipple? I’ll do the manual lever way next time. Much more efficient.
Abs has been broken for years and mentioned earlier in the thread I’m hoping it’s fixed now I’ve repaired the rear abs sensor. As I understand it, I abs II has a straight through circuit that allows the whole system to be bled manually? It might not get all the fluid out of the unit itself but the brakes are hydraulically actuated and if the abs is dead so what!
As for Joe duffy, cheaper to buy a 911!
I no longer have a GS but I used get the old fluid out with a Mityvac, firm it up with the tube into a jar of old fluid and give it a final buzz with the GS911.
delighted with the little wrench. doubt it'll survive even one drop but amazing value. used it a lot today.View attachment 530230View attachment 530230
I’m now the proud own of three torque wrenches. My old one was left half wound for five years so don’t trust it but at least I can test it against the big one.
Scored so 8mm steel bar. Should be handy enough to make the bmw flywheel locking bar.
Bought a new relay. Thespoys niw turn off with the ignition. Hurrah.
It’s a small victory but I’ll take it!
I got left-hand bits from HMC Tools and Equipment off Killeen Road when I had to replace exhaust studs on a CBR. They also do taps for retreading.Lidl has bits are shit.
This bolt is rust welded in there. Anyone any suggestions? Drill the rest of it out? With good bits? Note my photography light doing some heavy lifting.
View attachment 530790View attachment 530791View attachment 530792View attachment 530793
There is a great place up in finglas as well. https://allmetalfasteners.com/I got left-hand bits from HMC Tools and Equipment off Killeen Road when I had to replace exhaust studs on a CBR. They also do taps for retreading.
