Confused....Media player ?
Not open for further replies.
Spud
Fylde England
My Nav 5 has worked fine for the past couple of years. Last night I was listening to music (Sena SMH10) when it suddenly stopped.
The screen with the music still appears, you can still search all the music on the SD card, but if you press the "play" button, nothing happens (doesn't change to pause or anything)
The usual routing voices are fine, I've taken the SD card out and re inserted it. But still the same...
Any ideas ?
To listen to the music, as you know,it's got be paired to the Sena. Un pair both then re pair ,see if that helps
Thanks DC
Not sure what's gone on, it was paired as I was still getting the direction voices and the media"page" was appearing (doesn't if no pairing)
Anyway, done a map update and all's well again, so not a clue :rolleyes:
Thanks for the reply though
Spud
