So the B6 and B7 on the bench with a usb cable, at least the original from China land, will power up on 5v usb-c. It takes a little bit over an amp.
The problem, at least on the unbranded version from WEUASTE, is that the unit requires more than 5 volts (it will power up, but NOT if set to full brightness ...if you can catch it in time to turn that down, it will stay on)
What I did was make a USP-c cable with a PD Decoy for 9 volts in the smart charger end. The decoy triggers 9 volts, the charger powers up and the unit runs perfect on the bench from usb.
I hope that maybe helps.
EDIT add: It is not the power of the charger, it is the voltage, so you need a smart charger, and a decoy to trigger it to 9 volts. There is no usb PD negotiation built into the units usb port at all ...or turn the brightness down to 30% when on the bike, then on the bench it should stop continuously rebooting
