Anyone tried buying a sim in Morocco or data ad on from ee?
You can buy data SIMMs at the port, Tangier Med.Anyone tried buying a sim in Morocco or data ad on from ee?
Only useful to later model iPhonesAnyone tried buying a sim in Morocco or data ad on from ee?
I’m not sure if Morocco is covered but EE offer a Roaming upgrade on a month by month basis (turn it on, turn it off) as you require. About £11+VAT ish I think.Anyone tried buying a sim in Morocco or data ad on from ee?
Sorry but as I said esim is only available on iPhones x and onwardsIn addition to my above recommendation
a bit of information on how to do it.
Get your eSim from Airalo, the process will install it ready but it will be inactive.
So you can buy in advance of arriving the country you need it for.
So if you bought a 7 day eSim, the 7 days only start when you start using it.
You will be emailed instructions when you purchase, but here's a guide.
On a Samsung/Android (apologies it's what i own, for an Iphone it will be similar)
swipe down and click the little cog top right the enter settings
you will see this (only yours won't have my dog on it
choose "Connections" circled in red above
you will arrive at this next screen
Choose SIM manager as circled in red above.
you will then arrive at the screen you need below.
If you have a physical sim card you will see your normal sim at the top of this screen
if like me you are already using an eSim you will see it in the middle section like me.
At this point, if you have already installed the eSim supplied by the Airalo App you will also see it here, but it won't be getting used yet.
That's because the bottom section will be all set to your normal UK network.
Once you arrive in the country you got the eSim for, click these and change them to your NEW eSim.
If you want to make sure you dont get ANY roaming charges you can opt to untick on the right your UK network sim completely turning it off.
Now you will have to use only the new eSim for data and calls.
That's it
Just as a side note, you can still use WhatsApp like normal even though it's obviously attached to the telephone number on the deactivated UK sim.
It will work just the same
So if you need to call someone just voice call over WhatsApp for free, and people can call you the other way free too![]()
Thanks, when I last visited Morocco with an ee plan I bought an ad on which lasted all of 40 seconds. I intend to by a local SIM card and will report backI’m not sure if Morocco is covered but EE offer a Roaming upgrade on a month by month basis (turn it on, turn it off) as you require. About £11+VAT ish I think.
I’m still on a business contract so I’m not sure if it’s available for ‘retail’ customers.
I can turn it in and off through the EE App.
I’d certainly look in to that first rather than some of the options mentioned above.
Sorry, I probably didn’t explain very well. I don’t buy an add of of X amount of data.Thanks, when I last visited Morocco with an ee plan I bought an ad on which lasted all of 40 seconds. I intend to by a local SIM card and will report back
Maroc Telecom - best network coverageI intend to by a local SIM card and will report back
I had that in my phone bought just after control topped up by friends and phone shops everywhere.Maroc Telecom - best network coverage
INWI - best data packages with the unlimited option![]()
Is this the world wide one??Well I bought an orange data plan on arrival and so far it’s working a treat
