Slowcoach
Grateful for any help or ideas on this one.
My 2020 GS has a Datatool Stealth tracker fitted. It has worked fine for a couple of years but recently drained the battery so much the bike couldn't be started.
The dealer has tried to sort this out under warranty, fitted a new tracker and new battery after liaising with the Datatool techs. The problem wasn't solved.
So prior to my holiday I asked the dealer to disconnect the tracker and sort it out when I get back. After a great biking holiday I'm back, but the dealer can't fit me in to sort out the tracker problem for three weeks (but that's another story and my next bike won't be from them!).
Bearing in mind my confidence in both dealer and Datatool techs is now zero, I wondered if anyone else on here has had the same problem? If so, what was the solution.
I think you guys probably know more than the so called "experts"!
Thanks for your help.
