_Simon_
Guys,
On my 850gs, I haven't been able to disconnect (pull apart) the high pressure fuel line under the tank (prior to removing the tank). I found I could remove the low pressure pipe by twisting it and then pulling it but the high pressure pipe just won't budge. I've tried pushing it off with a screw driver but not even that will work.
So how is it done? What has caused it to stick? Can anything be applied before re-assembly to stop it happening again?
Plus .... The end of the fuel pipe shows cracking on the inner surface. Is this normal or should the pipes be changed?
The reason for wanting to remove the tank is to drain water out of it. I tried siphoning it out but can only get the siphon to go to one point in the tank and that's not the lowest point. The filler has a flange, which I guess is there to force the fuel to the pump side first when filling, and this restricts access to the whole of the left side.
Thanks for help on any of the above.
Simon
Simon
