DOT4 Brake Fluid
Great news, I don't have any motorcycle fluid here but a few bottles of DOT4 for cars :D
i only mentioned it as i had visions of multiple half empty old containers lying around on a shelf somewhere :D
Dot4 is same for cars and bikes. Different brands have differing boil points and can keep working where the cheep stuff could have boiled, I think you'd have to be into racing to test the theory though.
Why do we not use Dot 5.1? Its less hygroscopic that Dot 4 so less risk of caliper corrosion. Just asking.
In reality - the remaining fluid can only absorb the humidity of the air in the bottle (if top is on) - which in normal UK conditions, will be the thick-end of shag-all.
Once it has done that - and the air in the bottle is dry- that's it!
Wouldn't worry me
Al
Wouldn't worry me
Al
Indeed. Different when it was tins with crappy fitting lids.
How much steam can 1 drop of water make? It's a hell of a lot there is a formalua to work it out. I think it's over 20 times the volume of water and enough to kill. It causes vapor lock. JJH
Where does the drop of water come from ?
Look, we're not talking about using some old dregs that have been kicking round the back shelf for years, but I've seen guys throw out perfectly good brake fluid in a tightly sealed plastic container thats been open then sealed back up and sat for a couple months.
Its your choice.
Its your choice.
Yes once you know yourself the histroy of the container. JJH
water to steam expansion ratio is 1700:1
Alan R
