Which grease do you use on which component?
Staburags is used to seal the gaiter to fd/swingarm. Optimol is for the spline to shaft
Not as expensive as water getting past the gaiter.
It also goes a long way.
Cheers, what about the needle rollers in the pivots, normal LM grease?
What`s the white suff i see blathered about the final drives, is that the Staburegs? Sure i`ve seen it on the splines, too..?
Given that virtually no grease exists on the splines. A moly based marine grease is a good alternative at a quarter of the price
I prefer to use what the manufacturer uses.
As they're often accused of penny pinching, there must be a good reason to use the expensive stuff?
My 2021 had no sign that the Castrol moly paste had been used during manufacture.
Mine did.
Given the discussions on here about the rear drive spline, when my 2019 R1250GS was in the workshop recently being serviced I asked if they could grease the rear spline. The Service Manager - whom I should say I know pretty well and trust - said that if I really wanted it done they were prepared to do the job, however on these later GS's there is already a thin covering of grease which should be sufficient to stop the spline seizing; He went on to mention that he was fully aware of the various forum discussions on the subject, but that his recommendation for the 1250's was that it was not needed.
You're late!
