Electrical gremlins
Vern
Toy maker
A bit south of Chester
Right you geniusisisisi, help me out with this one then.....
94, 1100GS. The two indicator idiot lights, the full beam light are on all the time at half brightness(ish) and they also dim in time with the ABS warning lights. The speedo light also joins in at the same time,sooooo, a bad earth I think, but where is the question.
I've had a half hearted poke at it this afternoon, to no avail, so has anyone had this problem before, or has had heard of it and can shed any light on the subject.
Everything else seems to work just fine.
Whatchathinkpeople:confused:
Rectifier
Seem to remember that my R75/6 had these symptoms and I finally traced it to a duff diode in the rectifier board. Also made a mess of the starter solenoid and the battery.
Split the main loom from headstock to clocks and you will find that one or more of the common earth for the idiots lights are broken off and it's using the other lamps to ground out thru
Just trim back and solder the joints instead of them being crimped that should solve the problem
Bang on the money. A litttle tip you probably know, if the bare wire is discoloured (usually blackish) you will have to 'fan' the strands of wire and clean them with fine wet & dry or something similar and use plenty of flux otherwise it will be very difficult to solder and usually ends up with a dry joint.
That all seems far to simple,I was expecting someone to say that I'd need a new engine and gearbox to cure the problem:D
Thankyou one and all,I will report back with my findings, but I suspect the wiring to the idiot lights is the culprit,as I moved them to the top of the screen about ten years ago, and had to extend the wiring,so that's probabaly gone manky over the years.
Ta muchly:beerjug:
What Jay and the Ugly Cow say Vern. :thumb2
Had a similar problem last year and it was Steptoe that put me onto the little loom from under the tank to the clocks. Easy fix. :)
I was wondering how long it would take for you to appear:D
Oh, alright then :D - I agree with the earth crimp malarkey - my old bus had just that happen - clump of green fur and a couple of broken cables where the crimp is :thumb2
Hit it, or better still hit Matt with a feckin big hammer. Problem (both of them) solved. :D
At last, the sensible suggestions are coming in now.
Where do I find the canbus tank? I think I left it under the stairs last time I had it.
Outrageous replies to your sensible question. I would have flounced long ago.;)
Errr, yes back on topic, my advise is use shrink wrap rather than insulation tape, it lasts longer.
2 years ago, I re-orientated my rear indicators to miss my panniers, ran out of shrinkwrap and some wires ended up being taped, subsequently re-did this job in the summer and the shrink wrapped wires were still perfect, the taped wires were green/black and rotten.:blast
Thats a very expensive option so just flog it quick, put it on ebay just tell them it's a special xmas edition with special lighting effects. (or the Harley
site!).
Dave (always trying to help?) GS
I assume you mean heat-shrink rather than summat you wrap your sammiches in?
Oh yes, i completely forgot about the main earth crimps in the instrument loom during our conversation yesterday :blast
That'll teach me to drive and talk at the same time :hide
Update...........
Well, today I had a bit more of a poke at it, and all the oils are just right,so it can't be that:blast
On the other hand, the electrics to the idiot lights are pretty comprehensivley
Donald Ducked. All the joints I done many moons ago,heat shrinked and silicone sealed:cool: are absolutley fine, however, the ones Mr Mbw done,are shite. It's not worth the effort of messing about with it, so for 20 quid, a new second hand one is on the way.
All I have to do, is extend the wires and away I go(if I plug it in and everything behaves of course)
I rode home with only the indicator light stuck on for company,so I did manage something today:D
I'll report back with the results in due course:thumb2
