I put the bike on its centre stand to start the final drive oil change process and I noticed whilst undoing the wheel bolts that the rear wheel needed a bit of effort to turn it. I put this down to a sticky brake calliper as it has been sitting for a couple of weeks.
I got the wheel off and the calliper, speed sensor etc. and it is just as bad, needing a bit of effort to turn the brake disk.
I have drained the oil, black and sludgy, greased the pinion with CV joint grease and fitted it back in to the driveshaft. There was no play in the pinion and everything was clean and bright with no visible signs of wear.
However there is no discernible difference in the effort needed to turn it, it is still difficult where I imagined the wheel would spin. I’ve not filled it back up with oil yet or put the wheel etc. back on.
Is this a normal trait with the final drive, am I worrying about nothing or should I be concerned?
Forgot to say, it's a 2006 GS with 20,000 miles on the clock.
