Final Drive Failure Register
Regardless of how reliable the rear drive is, my biggest beef is that it isn’t really DIY repairable (for the average spannerman). That is where the design fails.
The special tools needed to strip and replace bearings are nearly as expensive as a new replacement unit. BM have you by the goolies. Unless you can find a good independent (who’s willing to invest in these tools).
I’m not bothered by the failures I’ve had – it’s mechanical – it will break – hey ho.
But it’s just too much hassle to get sorted. And with a major failure, expensive too.
I’ve had a few BMs over the years and never had any trouble with the rear drives – except for the 650 Dakar – but that was an easy DIY fix - repairs and maintenance of chain drives I can cope with.
Would I buy another 1200? - No. I don’t want the hassle/expense again.
So, in nearly 50,000 miles what’s gone wrong:
3No outer seal failures – all DIY repaired – quick, cheap and easy (no bother)
1No bearing (big dry one) at 30,000 miles – cheaply changed by independent (slight hassle)
1No complete unit replacement at 45,000 miles (caused by failed driveshaft bending final drive shaft). Currently trying to get old unit repaired to have as a spare – but special tools wont fit due to bent shaft.
Now, only problem left is to find a 1200cc air cooled flat twin with chain drive :blast
:blast Can't believe people are still on about this. The bearing will wear out.That's what it does .
It will in most cases last 20-30K that's what it does.
It won't collapse like the 1150 That's what it does.
It won't normally last as long as the 1150 That's what it does.
It will go on for a good few thousand after you feel the 1mm wear. That's what it does.
We all know these facts, some last 10k some last 60k on average they last 25k.
It's a fact of life, get over it or buy a different bike.:nenau it's fucking simple
You won't find another bike as good though :blast
that's a fact too:thumb
What a great rant!! :blagblah
The thing is, if people weren't interested in keeping up with the failure rates of the well known and unaddressed issues with these bikes there in fact wouldn't be threads like this.
From what I've seen, Beemers pretty much hold the record in this area, so in a way they actually are number one in something! :thumb2
100% right:thumb It's a known issue so you budget for a new one (like you would for chains and sprockets) or get it rebuilt at sensible mileage for piece of mind:thumb
Dealer rang me on Tuesday and stated FD had been overfilled.Joe Duffy BMW of Dublin were responsible because they repaired the first failure at only 5000 miles.My bike is at Charles Hurst BMW Newtonabbey and I'm going to collect her tomorrow night.I've already been told its not covered under warrantee but will take it up with the manager.The FD must have been overfilled when I bought then for to fail at 5000 miles.
If the seal leaks then yes over fill can cause,this.
As for the big dry bearing no over fill can't cause this
The bearing can fail for many reasons but overfill is not one of them
Done 30 bearing this year some have 240+ml of oil
Got another to do this week .again very easy with BMW tools and yes there cost a fortune :blast
Probably the issue is highlighted by owners because they are new to BMW and expect better performance from a premium priced "unstoppable" motorcycle.
Remember, most have come across from years with Japanese manufacturers and the idea of extended warranties and budgeting for breakdowns has never been part of their motorcycling experience.
Most Jap bike owners do a fraction of the mileage of your typical GS rider - many are fair weather riders only.
BMW is not a premium product - the competition is just as expensive.
Chains and sprockets need replacing as well - and are not cheap.
I think you mean "most jap sports bike owners do a fraction of the mileage".
Where do people get this idea that only GS's tour and do high mileage? When I'm in Europe I see just as many Japanese bikes as BMW. And as far as "fair weather riders" go, look at the mileages of second had GS's. Plenty of low mileage example.
Instances of shaft drive issues with other manufacturers don't seem as prominent. Police ST1100's did lots of miles, as did ST1300's. FJR's are around with lots of miles, etc., etc., etc..
Aaaaaaggghhhhhhh .
That's the whole ferkin point .
Fd failures shouldn't be happening .
The japs can get it right on the tenere. Why can't BMW on a more expensive product .
It's a good bike but alot of you guys are doing the ostrich impression reference the reliability !!
