Do you know why BMW switched the FD to the left hand side on the new WC ~ it’s so you can check the FD when getting on / off the bike. I, grabbed my old GS out of the garage today, checked the tyre pressures and whizzed round the block. So nearly 100 miles later I get back home, happen walk around the bike and notice oil over the right hand side of the rear tyre. The actual tale woe is this:
July 2004 0 miles bike registered
May 2007 10,700mi 1st FD sheds oil over rear tyre. FD replaced foc by BMW
Sept 2012 34,510mi 2nd FD has play & noisy rotation. Bearings replaced £265 by BMW
Feb 2014 37,991mi 2nd FD sheds oil over rear tyre.
So after less than 38,000mi I can’t help feeling BMW have a QA problem with FDs (assuming there is no underlying prob on my bike causing the failures such as misalignment or duff rear shock ~ the bike does bounce a bit
). My question is, do I go back to my BMW dealer and relate the tale of woe or engage the services of an experienced engineer from this ‘parish’ to undertake the repair using proven (non BMW?) parts. FYI the bike is not ridden off rode, has BMW FSH and there is no transverse play or noisy rotation at the mo. What should I do guys? All constructive comments and actual contact details for non BMW repairs welcome! If you want to speak directly pls text me on 07973835184.
