Final drive paint.
when the powder coat starts to lift it peels off in big chunks:blast i would imagine that trying to respray would look a bit naff,better to wait untill the unit requires a rebuild and get it blasted and recoated at the same time:thumb
Even worse when alloy corrosion gets under the paint it runs riot and chews into your metal under a harmless looking bubble.
If its the same paint they use on the wheels, shot blasting will gouge the underlying metal before the paint is cleaned off. My powder coaters did a test and pointed me straight to -
Enviro-Strip (UK) Ltd
(Previously ThyssenKrupp Services Ltd)
Warwick House
Watling St,
Wilnecote,
Tamworth
Staffordshire
B77 5BH
Tel: 01827 281296
http://www.envirostripukltd.com
Chemical stripping was £14 a wheel so probably much the same for a rear swing arm. They came out looking factory new before they were painted.
Dont go near a normal paint strippers - caustic soda dissolves aluminium.
