Indeed it is. However when these drives were first made, BMW specified 220ml. Why is it now 20% less? A few drives leaked though breathers or seals so BMW gradually dropped the oil levels. No oil. No leaks. These "failed" FDs were never repaired being simply swapped out under warranty which runs to 30,000 miles. If its internally knackered at 35,000 its not their problem.
Is the reason why BMW dropped from 220ml to 180ml because the FD does not have a "breather"? I note on my other shaft drive bikes, they all have breathers on the FD and ive not heard of any non-BMW FDs failing. Just curious.
The R1200 final drive is flakey. end of. Quite why BMW chose to redesign the 1150 back end is anyone's guess. Maybe they saved a few grams but I doubt it. TBH they could have put the front swing arm on a diet. It's a solid casting enormously heavy for what it does.
I know - it’s a big weight saving but they went OTT on the final drive. Design is weak.
Front swing arm is solid metal. It could have been steel tubes and saved a bunch of weight. Use that weight somewhere it needs to be.
Front beak frame is metal tubes when the whole lot could have been plastic.
The plastic under pillion seat is really heavy what for? The GSA then duplicates that with an afterthought stainless steel frame. One or other but not both.
The list goes on.
