If you hold the bike on the rear footbrake only when stationary, the Servo pump will stop after a few seconds and then give a small pulse every few minutes to check/rebuild pressure.
Don't keep the front brake lever pulled when waiting at the lights etc as the Servo pump will run continuously and cause excessive load on the charging circuit whilst at idle.
Things you learn by riding it..... didn't find any of that in the users manual.
Once again, I wholeheartedly recommend the Hawker Odyssey (AGM cell) battery and CTEK Multi XS3600 charger, both available at Motorworks for a decent price and it solves all your battery problems.
