Northern Monkey Registered user Joined May 13, 2010 Messages 761 Reaction score 0 Location preston, lancashire Aug 8, 2018 #1 I’ve found steptoes guide in the 1150 section on how to change fork seals...... are the 1200 basically the same ?? Or do I need to look elsewhere?
Ian J Hartley Well-known member UKGSer Subscriber Joined Jun 15, 2003 Messages 5,106 Reaction score 457 Location Swindon, England Aug 8, 2018 #2 Northern Monkey said: I’ve found steptoes guide in the 1150 section on how to change fork seals...... are the 1200 basically the same ?? Or do I need to look elsewhere? Click to expand... Quick look at the parts catalogue will show that the geometry is the same.
Northern Monkey Registered user Joined May 13, 2010 Messages 761 Reaction score 0 Location preston, lancashire Aug 8, 2018 #3 I was referring more to the ‘technique’ of replacement being the same and therefore I’m safe to follow the guide for the 1150 , but thanks for the info , if they’re the same there’s a strong chance
ferguscawley Well-known member UKGSer Subscriber Joined Oct 23, 2003 Messages 1,219 Reaction score 9 Location Cork, Ireland Aug 12, 2018 #4 Northern Monkey said: I’ve found steptoes guide in the 1150 section on how to change fork seals...... are the 1200 basically the same ?? Or do I need to look elsewhere? Click to expand... Can you share the link please ? Thanks
Northern Monkey Registered user Joined May 13, 2010 Messages 761 Reaction score 0 Location preston, lancashire Aug 12, 2018 #5 Fork seal fitting https://r.tapatalk.com/shareLink?sh...om/forums/showthread.php?t=97873&share_type=t The pictures don’t seem to work anymore but seems self explanatory
ferguscawley Well-known member UKGSer Subscriber Joined Oct 23, 2003 Messages 1,219 Reaction score 9 Location Cork, Ireland Aug 12, 2018 #6 Thanks Sent from my SM-G930F using Tapatalk
