Front high fender for an Xcountry
r1d3rg652gs
Greece
Could anyone recognise which aftermarket high fender this is?
Is it possible to install the Xchallenge high front fender to Xcountry? Does it need to install the Xchallenge headlight as well?
Thank you.
I think it’s this one and it will work with the XCountry headlight even though it says it’s just for the XMoto , it just doesn’t utilise the two locating pins in the headlight surround plastics
Here’s is one I fitted to a custom build a few years back , this one also had an extension piece from Touratech fitted
Thank you. the hypermoto short one I am not sure how it will look. Maybe in the end will be easier to get an Xchallenge and lower it.
You could always buy my custom XCountry ;-) . Might be a bit expensive to get it to Greece though !
I would if I was in the UK. Your front wheel is still a 19? What components did you have to install in order the Xchallenge fender to fit?
An alternative is the high mudguard from the F800GS, similar age one, not the new one. This is on a Challenge, but they are the same bikes.251440728_10220314349960860_8582386013390977194_n.jpg
I love that one from the 800GS. I was trying to find a nice fender for my XCountry and eventually managed to fit one from a Ducati Enduro which looks pretty nice imho.
