Hi I need some advice on front wheel bearings...
Is it possible to replace them at home or it is a dealer only job? I took the front wheel off naively thinking I could drfit them out put there is no space to get anything behind the bearing as the internal spacer runs from bearing to bearing.
The manual show a puller/spreader. Has anyone succesfully changed them at home or do I need to get the dealer to fit them? I do not mind buying tools to do the job if they will work. I have a hot air gun and freezer so heating the housing and cooling the bearing is not a problem.
For referenece the one bearing looks dry and there is some slight rust and the other is covered in grease (it's own?). 2004 GS on 53000 miles.
Alex
Alex
