Fuel filter life
AdrianS
Harlaston Staffs
How often should the fuel filter be changed if it is not changed on a mileage basis? Do they deteriorate over time?
I know some cars ( eg BMW Mini ) have a long lasting filter that doesn't need changing and is fitted for the life of the vehicle!
The filters are broadly the same, the only difference I can see is that most car ones are about five or six times the size of the BMW item, I think the book says that the bike one should be changed every 24K, sometimes a dirty one will make the fuel pump whine. (as will being low on fuel)
How often should the fuel filters be changed
How dirty is your fuel?
If you go with 24k as a maximum but change more regularly if you travel the wilder parts of the world (Hull for instance), you won't go far wrong.
As to deteriorating over time - who knows. Change it if it bothers you
I've taken a fuel filter to 42k with no problems.Depends on the quality of fuel you put through it.Triumph and Ducati use the same fuel filter.
The "Triumph" branded version costs a fair bit more and they recommend changing it every 12k miles.:augie
As someone said,a noisy fuel pump is a sign its working harder to draw the fuel through.
If you have a BMW Mini I would have a look at the fitted for life fuel filter. The one I replaced on SWMBOs Mini was more a solid block of black stuff.
Adrian
