Dusty
So.... brought the bike out 8f a two month hibernation... start first time as usual... give it a run then put it away.... ive been charging it periodically over the last 3 month....
took it out for a run out on Wednesday past it was pishing down... but that doesnt bother me much... on way back from squires to Thirsk I noticed the fuel light was on dim... not dull brightness like im running out of fuel... but fuel tank half full.....
continued a run to thirsk then back to home... absolutely no problems .
had a look at the bike today... grease and cleaned a few non fuel related bits... turned on ignition to find the light was still on... tried to turn the bike over and battery was flat....
checked all batt connections and had a squeeze of the wiring loom and the back of the light itself but no change.
im a bit lost.. im thinkin possibly water ingress somewhere or a faulty fuel light switch if there is one... but I cant get my head around the flat battery bit..
would be grateful if anyone has a steer for me to look at..
grateful
dusty
grateful
dusty
