Fuel pump controller workaround
Thanks Wapping - a very clearly illustrated fix. :thumb2
I hadn't paid it much attention until my FPC failed yesterday (at home :D). Nipped out and bought a new one, but will look at making a "get-u-home" lead from the old one -as you describe (from Optimate socket)
Cheers!
Al :thumb2
Oh man... Let's see... In no particular order:
Your new battery will fail just as the original one. They're all useless. Switch to Odyssey.
Your windscreen will rattle.
You will experience an oil leak between the gearbox and clutch.
Your front breaks will squeak and rattle.
Your new fuel pump controller will fail just as the original one.
The antenna thing for the key will fail.
Your topbox will crack and fall off.
For a start.
I find it incomprehensible that the germans managed to engineer this fantastic bike and yet seem unable to produce it.
Hmm
I was going to ask if anyone would suggest waiting for the twin cam 1200 (if it materialises) as a replacement for my 1999 1150GS.
Richard
Replacement FPC
Just had my FPC replaced under UK recall.
On checking when I got home I note that the new unit is all black whereas the original Sept 2007 was bare alloy.
I also noted that the dealer had sprayed a protective film over it and I added another dose of AC50 just to make sure.
Hopefully the new unit will be totally reliable although I had had no problem to date with the old one.
As a matter of interest the dealer who fitted the replacement was Cannons, Braintree.
There has been a load of flack over the years aimed at Cannons and I accept some might be valid but in all the years I've dealt with them buying new bikes and having all my bikes serviced here, apart from a couple of minor errors, I am happy with them - there have been staff changes and Kate is back for three weeks at present!
Mike Davies
fix
Hi picked my new gsa last week and there were 2 gsa owners complaining about the same thing .This is my first bmw Looking at your pitchers you would think that bmw would make a cover like a head lamp to stop the water geting in the first place. Big Loz
Does anyone know whether the FPC connector is teh same as a standard HID connector? (or if not where can I buy the connector please)
Think its left open to aid cooling,thought about encasing mine[earlier 07 model with the recess] in silicone but didnt for the same reason.
Have had no problems with mine to date but carry a spare unit jic:augie
Bit late now but for anyone else........Dealers are chucking dead FPC's in the bin, ask nicely and most will be willing to give you one to cannibalise ;-)
A couple of different methods of FPC work-around / making an FPC bypass here:
R1200GS failed fuel pump controllers
So I did, by eamail, today.
I wonder if you can help me, please?
There have been several (probably lots, if your dealers' responses are genuine) well documented reports of the fuel controller, that sits on top of the fuel pump, failing on 1200GS and GSA machines.
Quite why the controllers are failing seems to be a bit of a mystery. The answer, depending on who you talk to, seemingly ranging from:
(a) They get flooded. I guess this is linked to the pool of water that they often seem to sit in? Possibly explaining why the 08 GS now has a more sloped recess for the unit?
(b) They are getting overly hot and 'frying'.
Leaving aside the precise cause(s) of failures, I would be interested to know:
(a) What the controller does, precisely. Again, there seems to be several theories but no definite facts.
(b) Whether - as a simple 'Get you home bodge' - it can be removed?
What is well known is that, when the fuel controller fails the bike is left completely immobilised. So, having a 'bodge' - to at least get you moving towards home or help - would seem practical and sensible, especially on an 'adventure' motorcycle, notwithstanding the efforts of BMW Assistance, obviously.
Using the female plug off a failed controller, I lashed up a simple live power feed (via a fused connection) straight to the battery. This misses out the controller completely. Of course the fuel pump runs continuously but at least it is now pumping fuel. The bike will run, apparently as well as ever. The lead can simply be detached when at rest and silence is restored.
This is, as I said, nothing more than a roadside fix. I would definitely not want to run the bike 24/7 with this lash-up in place. I see it very much more as a real, in-extremis, solution. Indeed, to avoid using it at all. I now have one spare controller riding along with me, courtesy of BMW's spares department at Battersea.
I was wondering whether the lash-up was likely to do some unseen damage of which I am unaware? Or, whether, after several miles, somehow the lack of the controller would somehow 'confuse' the fuelling system, leading to other problems.
I hope that you can help me and look forward to hearing from you. In the meantime, my 06 GSA is performing faultlessly and is great fun to ride.
Thank you and kind regards,
I'm guessing they're still thinking, are they Wapping?
just had mine fail on a 2007 R1200RT at 60,000 miles
