My 06 1200 failed on 27th Mar, the day after I picked it up from the dealer... It is in Coopers Tun Wells waiting to be fixed...
Am I entitled to ask for the old bits back so I can make a work around fix as outlined here?
Also, how do I ensure that they fit the 'new and improved' one, which I think has a bigger O ring??
Should I then put silicon sealant around the edges or not?? Or is there a better solution...
TIA....
i have a o4 1200gs with 66000km on it and had no problem with it but here in aus we had a recall and they replaced the o ring under the electrical connector my be that could be causing the problem![]()
I'm getting a couple of questions about which wire is positive.
I have checked again and it's the blue one.
Other people have commented that their socket has a blue wire and a yellow wire, like the one wires in Tim's picture. That may very well be true. The plug I had from Robin of this parish had a blue wire and a white wire. Or maybe it was just badly faded yellow? Or, as Tim said, maybe BuMW just changed the colour.
Either way it doesn't matter, blue is hot.
Are you absolutely sure?
This is contrary to you post on the 1st page (post#13) that states Blue is -ve.....?
I have made a fly lead I'm just wanting to make sure I have it the correct way around......
Are you taking the power straight from the battery or via an Accessory socket? as there is lots of conjuncture about the CAN-BUS kicking it out (cutting power to the Acc scoket) , if you do it via the Acc. socket. ?
just a thought if its not been covered...![]()
Already been stated that the Accessory socket won't handle the power the FPC requires..
I've simplified things...Ran a connector straight from the battery to a point next to the accessory socket below the seat.. that's what the optimate plugs in to...
Then used the same type of socket for the FPC work around, and the Compressor for tyre repairs, so all are interchangable , and are working straight off the battery![]()
