Could you be a little clearer pleaseYou're going in the wrong direction trying to find the fault.
You're swimming from a long way upstream with lots of diversions along the way to the fault.
Start at the fault and work back downstream.![]()
Thank you i used a heavier wire and a 10amp inline fuse ,all seems goodYour break sounds like it is between the tank connector and the solder joint where all the green/white wires connect.
There is nothing wrong with what you have done and provided you have used the correct current rated wire ( or better ) should be 1mm minimum. Then every thing should work.
There is an old trick you can use if you need to chase a break in a wire, and that is to use a dress makers pin and push it all the way through the outer insulation until it makes contact with the conducting wire. When you pull the pin out the insulation should spring back to seal the wire.
During testing the ECU must be sending a signal to prime the pump because as i checked the relay and turned the ignition on i got a reading at the relay on the live feed out for around two seconds ,i assume this is the ECU sending power to prime the pump .
Perfect sensei just need to find the crimp and do a conductivity test from it to the tank connector and then back to the relay and find which side has the break in it
thanks for your time
