Gearbox problem
shaunj
Leamington Spa
Hi
Today while going to leicester i developed a problem where i couldn't shift gears. It felt like the lever was skipping on the splines, so i pulled over to check still in 6th gear, upon inspection i found the lever was tight and it was an internal problem so i tried to get neutral by hand but all that resulted in was the lever now has no resistance and just hangs down. The bike has been dropped a few times on the left side.
Am i correct in thinking best case scenario is a simple bent selector shaft? Which after looking at the manual seems a possible explanation and hopefully means i can be up and running by monday
Thats the best case scenario, clutch case off and check the gear shaft and pawl which rotates the selector drum. The shaft,and selector pawl should pull away with the clutch in place, anything more than that its a clutch drum off job. If its the selector forks bent etc it a major engine strip down.
It seems unlikley a bent shaft will jam the box solid without previous warnings or a sudden new bash. There are springs etc on the pawls which could suddely fail preventing selection (The R100/80 gearboxes are famous for it). I think a few early posts had a jamed selector due to a clutch fault?
Im any case good luck with your investigations, keep us informed (Please add the age of bike-mileage etc)
Heres the results of the investigation
Broken selector shaft
New one on order from wollaston costing £45
Bike is an 09 plate with 22k miles on the clock
You have a massive amount of good kharma banked somewhere to have avoided anything catastrophic with that!
Have you thought about buying a lottery ticket, lately?:beerjug:
Maybe but i would have thought there would be more reports of this judging by the number of bikes i see napping on ADVRider
I presume that you mean 'snapping'?
I'm fairly sure that there haven't been any on this forum. Is this happening elsewhere? Is it all in one country? Is there a common theme anywhere?
