GS1100 fuse blowing
Big Den
Warwickshire, England
No. 1 fuse has started blowing, taking out the ignition (batt and neutral lights) according to Haynes drawing its brake light switch and rigged into taillight. Stripped out taillight but still blowing. Any ideas ?
of the 3 in the tail light all go to earth and all go to the fuse :nenau
according to the drawing 1 is earth 2 is from brake switch 3 is from fuse so i am confused :(
unless the earth is switched :nenau
don't think i am going to make the mot appointment tomorrow :(
Den follow the brake switch wires to thier plugs and disconnet them one at a time
If the fuse stops blowing after you disconnected one or the other then the fault is in the disconnected brake switch
The warning lights look to me to be supplied by power from fuse 1, and then if there's a fault it's switched to make a circuit and light the warning / info up.
Does the fuse blow if only one brake switch is made or before you activate the brake?
think i have cracked it rear brake switch shorting to earth. thanks guys with your help fixed within the hour :thumb2
