GSA servicing costs?
I do the same on the 1200. I also print off the GS911 reports at the same time and add those to the service details. I use the BMW service forms which I assume are the same as used in the dealers. The alternator belt is straightforward - I used some plastic (1" x 8") under the belt on the top pulley and then pulled to get the old one off. To get the new one on I had a big flat headed spanner to keep the new belt in line and used my feet to rotate the rear wheel. It was in 6th gear and I had taken the plugs out to replace anyway.
Thanks Beemerman, I will bear that in mind when I change it. I also do the GS911 prints & BMW service sheets like you. It just makes sense.
Wapping, Chelmsford not too far from here so that could be a possibility, and beemerman59, I like the idea of servicing myself too, I have the tools and GS911 too...Mmmmmmm which way to go here ????
Kyrano, no brainer mate,, do it yourself, save money and know that it's been done well.
For a GSA, how do I obtain details of exactly what needs doing on each service please?
And as for service intervals, do I stick to this list which suggests every year including 6, 12, 18 & 24k miles?
You can ask your dealer to sell you the CD Rom.
No doubt there are copies floating around on the www too. Google may well be your friend or a search here may well turn it up.
