Left handlebar switch gave up this morning. Fine going home last night. Started bike this morning went for main beam nothing, from anything on left cluster, had to ride to work, will ring dealer today. Anyone else have switches fail.
I have had 2 LH switch assemblies since July!!
Had similar switches on my 3 K1300, no problem
Same for me, lol. Both left hand side and both apparently the new design, pffft. Mind you I do have IliumWorks barback risers fitted and they can cause a slight tension on the cables at max turn. I have set up the max angle on the bars before any notable tension occurs.
I have found that it is very easy for the electrical connectors to become slightly dislodged causing intermittent operation, poke a small flat blade screwdriver in there and push the 2 connectors in all the way on both sides of the flat connectors.
Before I fitted my risers I had velcroed a Drift Ghost remote control on the left hand bar, the tension on this on the cables was enough to dislodge the electrical connector in the left hand switch block, the ESA button did not work until I removed the velcro strap.
Last week I was cruising and the engine suddenly stuck at 3000 rpm, would not go up or down. I pull over, stop start, stop start, same problem. I pushed the connectors in a little on the right hand switch block and the bike fired up again.
I think my switch block problems I have had (#1 no auto light & #2 no high beam) are definately real faults with the switch blocks but that I have also induced a few failures by having the already snug OEM electrical switch cables in tension.
if they`re creating enough tension to interefere with electrical coonections and cause your throttle to stick at 3000rpm then somewhere along the line your going to have a nasty accident.
I`d take the risers off if I were youif they`re creating enough tension to interefere with electrical coonections and cause your throttle to stick at 3000rpm then somewhere along the line your going to have a nasty accident.
Just had both mine replaced by the dealer , April 2013 bike with 7000 miles.
Along with the engine, gearbox and drivetrain.!!
