Which year manufacture? The wiring differs from 2007 to 2008. There is no fuses. You are dealing with a CANbus network so the fuse trip is programmed. Check the bulbs and connections. It should have a warning on the dash LampF (front) or LampR (rear) or Lamps (meaning more than one). If you have the owners manual follow the instructions on chapter 8 pg 122.
Manual download here for your bike assuming it is 2008 model.
Normal filament has a correct length to heat up and provide correct resistance. A broken filament can drop across the wire prongs inside the bulb causing the fuse to pop or canbus to trip.
