Headset Question - Just Scala?
lank45
West Yorks
Is it possible to fit a headset to the 550 which isn't Scala, I'm running an autocom rider to pillion system and wanted to wire it into that and through my current headset, is this possible?
The Zumo 550 (infact the entire range) has a 3.5mm jack socket either on the motorcycle mount or on a flying lead (660) that you can plug all sorts of headphones or in-ear monitors straight into it.
However your Autocom should make it easier because you can get a lead (part 1314 I think) that connects the Autocom unit to the Zumo cradle.
Needless to say things may be different dependant on the Autocom version that you have but an Outfit like Chainspeed will be able to advise you.
Does this mean that a mate with Scala can talk to me via my Zumo/Autocom set-up?
