clutchspring Active member UKGSer Subscriber Joined Sep 22, 2013 Messages 470 Reaction score 253 Location leicestershire Apr 1, 2021 #1 Hi, can some one tell me if helicopter tape is suitable for surface's that get hot, like side engine case's, (not on a gs) or will it just melt. Thanks, Ian.
BobT Registered user Joined Dec 10, 2020 Messages 403 Reaction score 5 Location york Apr 1, 2021 #2 clutchspring said: Hi, can some one tell me if helicopter tape is suitable for surface's that get hot, like side engine case's, (not on a gs) or will it just melt. Thanks, Ian. Click to expand... It all depends on what you are calling helicopter tape.
MartinK Well-known member UKGSer Subscriber Joined Oct 6, 2018 Messages 2,886 Reaction score 1,662 Location Clackmannanshire Apr 1, 2021 #3 Most people would go for 3M 8671HS I guess..popular tape Had to dig around, and eventually found 160 degrees. Best check yourself, the spec pdf is not so clear... https://cdn.shopify.com/s/files/1/1604/3169/files/8671hs.pdf
clutchspring Active member UKGSer Subscriber Joined Sep 22, 2013 Messages 470 Reaction score 253 Location leicestershire Apr 1, 2021 #4 Thanks Martin, Ian
Greg Masters 'Don't mess with me' Member Moderator Moderator Joined Jun 25, 2002 Messages 27,830 Reaction score 3,760 Location Middle England Apr 1, 2021 #5 MartinK said: Most people would go for 3M 8671HS I guess..popular tape Had to dig around, and eventually found 160 degrees. Best check yourself, the spec pdf is not so clear... https://cdn.shopify.com/s/files/1/1604/3169/files/8671hs.pdf Click to expand... £200 a roll! 50mm x 33m
MartinK Well-known member UKGSer Subscriber Joined Oct 6, 2018 Messages 2,886 Reaction score 1,662 Location Clackmannanshire Apr 1, 2021 #6 It's not cheap. I bought some a while back to cover the wear areas on my carbon pushbike, and also added a bit to where my trews rub on the tank of my NC. Not used any on the GS tho.
RallyeGS Registered user Joined Sep 1, 2019 Messages 752 Reaction score 317 Location SE Apr 1, 2021 #7 https://www.vikingtapes.co.uk/colle...v1RdtrKE5-msIMDaiU5abetTuZD_EH-xoC7kMQAvD_BwE Available in a more cost effective length here.
clutchspring Active member UKGSer Subscriber Joined Sep 22, 2013 Messages 470 Reaction score 253 Location leicestershire Apr 1, 2021 #8 Thanks for all the replies , but at them price's I'll look at other options, Thanks, Ian.
RallyeGS Registered user Joined Sep 1, 2019 Messages 752 Reaction score 317 Location SE Apr 1, 2021 #9 You perhaps need 2m at most. £15 isn’t excessive
