west coast traveller
Following the earlier thread the bike made it to the Dragon rally and now "resting" in Carlisle. Still having some problems and wonder if anyone has had similar problems? GS 1150 twin spark. Starts fine from cold. Pulls away then once it shows one bar on the oil temp, it starts misfiring under load. Runs well on motorway with a bit of feathering of throttle and revs past 5000 but feels like the cylinders slightly out of balence ( I've checked them with mercury manometers and they are fine). TPS spot on and coil sticks replaced and plugs. Plugs are light grey. When warm the bike will tick over for about 30 seconds then revs. drop and it cuts out.
The other day I noticed that as soon the bike had warmed from cold starting there was an immediate change to it running rough rather than gradual deterioration.
I've gone over all the threads and can find some of the issues experienced by other members on the forum e.g cutting out at tick over,but nothing with all the symptoms that the bike is having.
I'm not sure if I am off the mark but I get the feeling that there could be a sensor faulty...oil temp (but gauge shows 5 bars when warmed up) or air box sensor. The injectors are working fine and have been tested.
Has anyone had similar experience or know whether oil temp sensor malfunction could be the cause? Grateful for any advice on this one.
