Help. Will not start!
dxwalt
Hampshire
I haven't used my 450 for three month, I've just gone to start it and it is turning over fine but it will not fire up. Any thoughts and where is the best place to look at first.
Fixed
Problem solved. It was the same problem someone else has with corrosion on the fuel pump relays which are located just under the ECU, I can't see why they left these unsealed but that's why they have corroded. :clap
Full marks for fault finding, will have to have a look at mine! You're right sealed would be good.
