Thanks all
Will use Fanums reply as template
Is it a full retail or oem version of XP or an upgrade disc? - OEM SP2
Have you backed up all the info, files, email account settings, favourites etc etc from the Vista install?? - Yes. Use remote drives in any case
Is the XP disc complete with SP2? - Yes.
Do you have all the drivers you need for XP SP2? Near enough
You're going to have to do a clean install of XP (IE delete the partition, format, install from fresh clean and shiny )......but make sure you have all of the above first- the SP2 bit for the USB drivers and a stress free install, the settings for obvious reasons and the full copy it vital. OK
The drivers should be OK....SP2 was really well sorted for them but if it's a new machine with new hardware, I'd double check and use the remaining time with Vista to prepare....download everything you need before you commit and stick it on cd....pay particular attention to SATA drivers as they are relatively new and not overly well supported on XP Sp2 - Nothing SATA in the box
EDIT....more info drekkly from MS on formatting under Vista
HERE
I want to go back to P as the machine just can't cope. I constantly get 'not responding' on apps, full boot and starting Outlook takes several minutes and the thing gets over stressed when asked to manage mail and web and an application at the same time.
The new disk stops installing and tells me that there is a newer installation of Vita and will not proceed.
I have other, older desktops running on XP that are just fine, if aged and a bit slow from time to time. Might just ditch the new one for now and go back to old faithful as the main kiddie.
Thanks again chaps - this must be the only bollocks free part of the forum to post in
Will try either the Msoft format line or get hold of the commercial version.
