WindyChuffer
Sorry for being a bit mechanically challenged when it comes to bikes. But can someone pls explain how you take the front wheel off? Is it just a case of using a 22mm allen key and loosening the pinch bolts? Do the discs just slide out of the pads and back in easily? Or is it a whole lot more complex than this?
Thx.
Thx.
VERY IMPORTANT - Make sure the ABS cable is routed correctly when replacing LH caliper - see "sticky" thread at top of this forum.
