How much for a service!
Berin
South Oxfordshire
Mrs Berin just had a 12k service on her 2021 GT Pro.
£668!
F**k me.
It's the 12K valve service, bit of a stinger every 12K, but I love the bike (I'm heading towards my 36K service now).
The intervals for servicing seem a little short at 6K, but given the 'new' engine configuration I dont fancy not getting it serviced on he button. Once my 36K service is out the way I will do the interim servicing every other 6K as it will be out of its extended 4 year warranty (next year).
I’ve heard of the 12k service on a Tiger 800/900 costing significantly more. I’ve had Ducatis and a VFR VTEC, and my Tiger 800 was the most expensive to service. I paid about £600 at my local bike shop- not a Triumph dealer, and the valve clearances were all ok.
23 years ago , when i worked at Jack Lilleys , a 12k service was £400 ish ....... by the time you had done c+spkts , and a pair of tyres , you were at £800.
Seems par for the course. Could be worse....15K service on the Multistrada is between £800 and £1K depending on where you get it done. My Tiger 1200 was £650 main service 5 years back at a dealership.
What hourly rate are the dealers charging?
I think valve clearance checks are one of the most expensive items on a service which we don’t now have on cars as they have hydraulic cam followers.
I think most bike services ( excluding valve checks) should take no longer than 1-1.5 hours.
Then there is the dreaded twat ( vat)!
As I didn't buy my bike from them my local dealership wanted to charge me more for a service than Triumph quoted on line. I'm unsure if this is common practice but it pi$$ed me off so I am having the service done by a local independent guy with a fantastic reputation. He is an ex-Triumph time served mechanic, will be using Triumph branded parts, has access to software / diagnostics & is VAT registered. This enables me to keep up the bike warranty & only time will tell if I have made the correct decision. Taking a stand for the little guy, ha!!
when i was a Guzzi dealer , i decided to have 2 labour rates , 1 for bikes we sold , and +£10/hr for bikes sold from somewhere else. i was very open about it .
bikes we had sold , got a proper PDI , they got a PDI i would do on my bike . A Cali EV , would take all day. most of the other bikes take 4-5 hours .
bikes from other dealers ,were not done as well , paperwork maybe not complete , AND you end up doing warranty work ( at half your normal rate ) on them .
WHY you ask , we were based in Wimbledon , and people would buy bikes cheap from dealers elsewhere , they still saved themselves a chunk of money.
we sold at RRP or very close to . we were always in the top 2 of dealers in the country for selling.
A good advertisment for buying bikes you can service yourself. That said I recently did the valve service on my Honda Africa Twin Adventure Sports. Took about 3 hrs to dismantle it, 20 mins to check the clearances and about 2.5 hrs to put it all back together again so no wonder honda dealers charge £600 for the check. I reckon now that I've done it once I could get it down to about 4hrs. That said I did the check at 18,000 miles instead of 16,000 and all the valves were in spec. Inlets (shim type) clearance 0.16mm +/- 0.03mm Three at 0.16mm and one at 0.18mm so all in spec. Exhausts (screw type) , 0.23mm +/- 0.02mm. three at 0.23mm and one at 0.22mm all in spec but I adjusted the 0.22mm back out to 0.23 as i had the correct adjustment tool that is the same as the valve ajustment tool for my Honda generator :D I kid you not!
My 390 Duke is just over 6 years old and not had its 2nd service yet. :D
Take a look at how much dealers charge just for the oil. I don't buy new bikes, I get them at 2 to 3 years old as they generally have very little mileage and cost a fraction of a new one. I then do all the servicing myself, I try to make all the specialised tools myself. I use all genuine parts and the recommended oils. I'm doing a full service on my BMW1200GS for about £100. I normally spend a day doing it as I will go over the whole bike and tidy up anything that looks like it needs attention and I do everything in the schedule every service. So if you factor in £100 an hour labour You can easily burn £700 to £800 on a service at a dealers.
Mine 1200 tc will be up for a service soon but as I have only done a few hundred miles since the last one I’m not too sure it will need anything doing ,bike has done 49000 .just started it up today cam chain seems a bit rattley
Could this be due to the oil having fully drained out of the tensioner.
As a side note if you have the work done by an independent operator and it needs something replaced under warranty do you pay upfront and then claim it back .
what do you class as a service ? big or small ? air filter , s/plugs , brakes ,chain , tp's , oils and filter , f/filter , f/injection . this list is not complete .
you could do an oil service in your 1.5 hours , and a check-over , but not much else. it depends on what bike you are working on !
as a point , i was given a FZR1000exup to do 1 day , service manage passed me the job sheet , he had 4 hours down for the time , i laughed and said what do you want me to do , he said full service with shims . i said , that's a 12 hour job , not a 4 hour job.
we went and looked up Yamaha flat rate manual ...11.8 hours ..... he rang the customer to sort it out.
VAT registered is irrelevant
Should be illegal to quote a non business customer a price that doesn't include VAT
I agree.
All depends on what needs doing.
I’ve had serviced done on bikes in the past where I have waited. An hour later - all done- that will be £200 or whatever. I do appreciate some jobs on bikes take considerably more time than on cars. Took me 1.5 hours to do the valves on my Himmy!
