Ignition stitched feed
karlp
Southampton, England
Anyone know if there is an ignition switched 12v supply near the ECU.
I know thy there is a socket near the front of the bike but trying to save me putting a wire from middle to front.
Not sure where the ECU sits, I'm afraid.
Could you tap into an early part of the rear light feed?
Not of course the rear brake light feed, as I once did :blast
Does the model still have the under the seat auxiliary socket? If so, that might do the trick, perhaps?
Under the seat where the 2 fuses are. True switched live. can't remember the colour but there's only 2 wires anyhow.
Hi
ECU sits immediately under the seat so I have put this super duper fuse box on top, but I need a feed.
Cannot use the rear light/ brake feed as they are now 5v ( being LED)
and
No rear auxiliary socket
I could find one by measuring voltages etc but would rather work with knowledge rather than just go bull at a gate.
Dealer says run a wire from the front auxiliary socket but that is a bit of a pain
Karl
Yep that's correct!
I think that it is the one with the thin blue trace, but I suggest that you double check with a meter!
