Ignition switch on twin cam tourer.
Rugged Path
The Honourable.
Wybunbury, Cheshire East, England, EU
I need to change the plastic ID tab (11) on the ignition stem as original broken in bits. While at it, remove the Ultra Classic plastic rear headstock cover which has the 4 switches on it for cleaning/inspection on the inside.
Therefore need to take off (17) to lift cover completely off.
Question;
Do I need to insert into the ignition barrel the special rod adapter to prevent the key indents moving?
As removing the switch (15), handlebars will be in the locked position when pulled out. And bars need to be straightened to remove switch cover.
Doing this at home so if I bugger this, I am stuck.
Sent from my MI 9 using Tapatalk
