Importing Saved Trip Logs
BRD
Worcestershire
Help please!
On my recent trip I've saved the current trip log each day on my 660 and given it name.
I thought that I would then be able to import these logs into Basecamp (I'm sure I've done it like this before) but the logs don't show up, the only one I can see is the current one.
Any ideas what I'm doing wrong??
Ta
When you renamed the track, did you by chance save it as a route, converting it from a track? If so, you are possibly looking in the wrong place.
On my 390, I too had difficulty finding some older trip logs, eventually found them in an archive folder on the unit that is not automatically pulled,in on syncing the zumo to pc.
Do a *.gpx search on the unit from a file explorer
If you saved them they will be in the same folder as the normal trip log, if you connect the unit to your PC you should just be able to browse to them and copy them over.
Connect the 660 to the pc wait for it to sync and then open the zumo drive locate the folder that is named gpx they will be in there if saved Maybe inside the archive folder , if you have an sd card with maps on as well, they could be on there, if so there could be a folder called garmin on your sd card and inside there a folder called gpx, look in there also. if you locate them you can copy and paste them to a folder and then open them with suitable software, (basecamp or mapsource will do) hope this helps
