Hmmmm,
Early 1200.
Let’s assume it’s had the immobiliser antenna,and fuel pump relay and ign switch replaced already.
Corroded primary and secondary coils.
Weak fuel pump
Final drive
Propshaft
Gearbox issues
Clutch,,,, kerrching
Slave cylinder leaking
Seized brake calipers
Worn top yoke bearings
Seized/ notchy telelever ball joint.
Perished swingarm boots.
Leaking balance shaft seal,
Abs servo failure
Seized alternator
Oil leaks from front cover,oil cooler pipes due to corrosion.
Shock absorbers failing.
That’s pretty much the normal stuff off the top of my head.
