Fit Noisy exhaust back on Tick gone
Eeeeeaaaasyyyyy! Solution
IN reality, Throttle balance might also be worth a look at, I have seen quite a few with no free play in the cables / Adjusters at all and the butterfly taps on the throttle stop a little, there should be about 2 mm just so it is not tight in the adjuster barrel (NB do not adjust the 7mm throttle rest stops with the paint on them That is a factory setting!)
But if you intend to go a ahead ... Pay attention to the Torques!!
If I recall there is 20 nm plus 90 degrees plus 90 degrees for the Head nut and 18nm for the Cam carrier cap (they are M8 with a Torx 40 or 45
When you see mentions of M10 its the big Allen bolt down in the cam chain tunnel Don;t be torquing anything where you are working to 40nm
Especially if that twat Botus mentions it!!!
Check/Set the Rocker end float !! THEN do valve clearances but if you can't slide the max clearance in, but
can slide the min clearance
I would say leave well alone If you still have a load of play with the Max blade in Yeah its worth doing
Usually I slacken the nuts bolts a "bit" (experience type of thing but don't be loosening them off all the way, Just slacken) fit a pair of Mid Range blades above the rocker and hold them and the rocker arms upwards and tap the cast bit upwards with a chunky hammer (N.B> TAP!!! ) when the blades are nippy Torque them up roughly and see how the blades move (if they don;t change don;t hit them harder slacken a little more
You want them to be a LITTLE nippy when you test but not solid if they are? Loosen again and light tight tap down and repeat process until you get the desired result
Once that's done I tend to use a pair of feelers (2 feeler for inlet and 2 for exhaust) on each valve bank 0.15mm on Inlet and 0.30mm and that 10 mm locknut? its NIP it up not wring it off 8nm
Have fun But they are an agricultural engine if you are used to 4 cylinders, so it may in the norm for us Old Hands but unsettling for you newbies
View and Download BMW R 1150 GS repair manual online. R 1150 GS motorcycle pdf manual download. Table of Contents: Replacing If Necessary - Page 46; Final Inspection With Road Safety And Fu... - Page 47; Technical Data - Page 52; Cutaway Drawing Of Engine - Page 59; Lubricating-Oil...
www.manualslib.com
