ahebron
I recently replaced all throttle cables as they where original and getting a bit threadbare.
Problem is I can get no slack on the LH one.
I have tried removing the lock nut but the adjuster winds down and still has no slack in the cable.
I tried Steptoes trick of holding the quadrant closed and forcing the throttle round to pop the lh outer into the splitter box but no luck.
The main accelerator cable is wound in on its outer sheath.
Could I have one of the famed shorter cables?
The next option is to pull out the splitter box and compare old and new cables, not a task I will enjoy.
Cables and splitter with update recently from MW.
Adrian
Adrian
