Lights problem!
  • Thread starter Thread starter sinbad76
sinbad76
Pulled in to petrol station this evening to fill up. Came out started the bike as usual and noticed the lights, indicators, brake lights are all dead. Funny thing is when I Turn the ignition to park the lights come on. Anyone any ideas?
Maybe a loose fuse so check all your fuses
Maybe the ignition barrel needs a little wd40 squirted inside
Maybe there is a connection block that is loose under or near the ignition barrel or head stock
Maybe damp in the handlebar switches....cant think of anything else but im sure someone else will be along to give you some more pointers...good luck.....Tosh.
