There’s nothing wrong with a lithium battery. And a lot right. Lighter better cranking will hold charge much longer and no you don’t need a special charger. Just a ordinary old fashioned 12 volt will do. No smart recovery types as they can fry the lithium battery. Think about it. What makes the charging system on the bike special when you fit a lithium battery? JJH
On one hand, a smart-charger with a built in conditioner should be avoided, as the conditioning means injecting high voltage into the battery.
But an 'Old fashioned' charger may be a box containing a transformer and a rectifier only, and should also be avoided, as these charger may inject too high voltage as well.
If yo buy a OEM Lithium battery, the battery will probably contain built in electronics, BMS (BatteryMonitoringSystem), and the BMS will protect the cells from high voltage.
But if you buy just a battery of proper size, you have to make sure you get one with the built in BMS. This is important, as there are batteries out there that do not have the BMS built in. These batteries may be used in vehicles without a built in generator (such as a toy car for kids), and these batteries are charged with a special type of charger.
If a battery without BMS is installed in a vehicle with a generator, there is no control on the charge current and voltage (taken care of by the built in BMS), and the battery may in worst case catch fire.
Replacing the regular battery with a Lithium battery may be successfull, but it requires the buyer to do his/her homework
