Lower pegs?
Nick dj
Baildon West Yorkshire
Has anyone fitted lower pegs?
What make, results did you get?
I have seen a post about putting on Pan or Deauville pegs on how much does this lower them and can you adjust the brake and gear levers to suit?
Not sure how much I need to lower mine but the brake side is the main problem as I have a low seat on.
Any advice would be welcome
ive got the tt ones,work well for me,that and a higher seat means a really relaxed knee angle:thumby:
Wunderlich do a pair, lowers them by about an inch. I've got a high touratech seat, but find I struggle a bit manouevering it and getting it off the stand can be precarious so may go to standard seat and lower pegs. I'm on an adventure though.
fitted wunderlich after much faffing with seat,used to get cramps after about 2hrs.dropped pegs 1" & cramps no more.luckily got a virtually unused set on here for a fraction of the price.they're well made and easy to fit.:thumb
my seat is on the low setting as i like to have a good footing with the weight of the bike.hence i fitted lower pegs as i found uncomfortable after a while and this solved it for me.its the small things that usually make the biggest difference.
