Megamoto heated grips.
Joe Bar
Too old to die young.
Not far away.
Although I bought my Megamoto new, I didn't order it and so it came without heated grips :( I've had heated grips on my last 5 bikes now so was a bit reluctant to go without. But, a quote of just of £310 from the local dealer to retro fit was enough to make me think I could manage without.
However, with autumn upon us and a recent ride out on my Rockster with heated grips on, my thoughts once again turned to heated grips. A bit of searching on the forums led me to belive that R1150 style replacement grips could be persuaded to fit so I ordered a par from Motorworks and set about the job of fitting them with a set of Symtec heaters underneath :)
As usual, nothing is quite as it seems and the Megamoto's existing grips are well and truly bonded to the plastic tubes they are mounted on. But, with a sharp blade and a bit of time, I soon had them all sliced and trimmed off. I did need to remove both grip tubes to do it, which was a bit of a fiddle as the handlebar switches are also mounted on the tubes, but nothing too difficult.
Next up I mounted the heater pad to the throttle tube and with a healthy dose of hairspray slipped the new grip on. I then moved onto the clutch side and hit a snag when the new grip just didn't want to stretch itself over the plastic tube and heater element. Got back on to Motorworks (great service) and ordered another throttle side grip to slip on.
Grip arrived, and with another splash of hairspray slipped straight on. Threaded the heater wiring through to the headlamp shell, and cable tied up alongside the existing wiring, so looks really neat.
I was hoping to fit the switch in the instrument surround but bracing on the underside prevented this, so I fitted into the left hand side of the headlamps shell, nicely tucked away. Wiring was pretty straightforward thecexisting, ignition fed, live plug for GPS / accessories is located in the shell, cable tied up and waiting to be used. I had some concern as to whether it was rated highly enough, but a few enquiries and a trial run has prove it ok.
Apart from the small loop of cable to allow throttle operation, everything looks very standard and unobtrusive, which is what I was after.
Re-fitted the headlamp and set of for a run, lovely warm hands :) :)
Pair of grips from Motorworks - £13.08 inc P&P (www.motorworks.co.uk)
Symtec Heated grip kit - £41.50 inc P & P (www.windingroads.co.uk)
Total - £54.58
Saving over £250, and as a bonus the R1150 type grips have a softer feel than the standard items so slightly less vibes as well - happy wiv that :thumb2 :thumb2
Heater element -
With throttle grip fitted -
Hi - Lo switch fitted -
Nice job :thumb
Are they as warm as factory fitted ones ?, just put some KTM ones on (oxford but ktm branded), not nearly as good as were fitted to my GSA..:o
Nice job :thumb
Thanks. The heater element ratings are very close to the BMW items, and back to back with my Rockster they do feel very similar, so well chuffed :)
Nice job Joe :thumb2
I too have thought about doing this but as the switchgear already has the cutout for the OEM heated grip switch, wouldn't the stock GS/GSA stuff have fitted? Or was that the £310 quote? Must surely be a fraction of that supply only?
By the way even if you had ordered your MM there is no heated grip option. Only option available is ABS.
True for the bike out of the manufacture.
But the dealer service computer can set up the option for the Heated Grips
option on the bike.
comodo........ : 211€
heated grips.. : 149€
I did it, works as well as on my previous GS1150 :thumb
Approximate breakdown was as follows -
Left hand heated grip - £50
Right hand heated grip - £50
Right hand switch gear - £150
Fitting - £60
Total - £310
So even doing it myself with supplied parts would have been £250, plus the dealer charge for pluggging into the computer to switch on the circuit.
Been out all day on the bike today, never had the grips off low setting, lovely :) :)
Joe, I thought I'd revive this thread because there are 2 things I'd love to have on the Megamoto that I have on my GSA.
Heated Grips. Am I right in saying that if I want exactly what I have on my GSA right down to the factory switch I can? For £310 I think according to your post above?
Ambient Air Temperature. Extremely useful for riding at altitude. Is there a GSA module that could be plugged in/programmed?
Ta :beerjug:
Ta :beerjug:
Yes, the BMW parts are an easy, if pricey retro fit. The canbus needs switching on by the dealer if you fit the parts yourself. All you need are the two heated handgrips and the rh switchgear.
Ambient air temp? Don't know about that one, but if you do find out, don't keep it secret, let me know too :thumb
